How much dynamic range is too much
Minnesota, the record label is BIS. The Beethoven Symphony cycle of Osmo Vanska/ Minnesota Orchestra is only available as SACDs.
sorry, I remember it was a double consonant elsewhere, but leaving an 's' to put an 'n' preserve the number of bits :)
I will not try to write Mississippi without before reading Mark Twain, hopefully I did.
I try to listen other recoedings from the conductor, this one is really forced to histrionism IMHO
EDITED: aha, Sibelius, this is another kind of beast. Let's try, first minutes and hadn't a heart attack, dynamic is under control :cool:
I suppose is both the conductor and the edition process, never listened Karajan in live concert but had the reputation of a very special sound.
Nothing against, he was one of the greats, and revitalized a lot the classical orchestra for the big public.
if you have some time to listen to Vikingur Olafsson (this time under Deutsche Gramophon) I'm curious to know more about his technics of recordings, I have the impression that places the mic inside the piano.
very special pianist, on the oppsite side of actual performances that exhibit a machine-gun like ultra fast version more on the athletic side.
I'm thinking about Yuja Wang and Lang Lang, more concretely, the public is more attracted by their speed than the expression
Arcady Volodos is even faster, but it belongs to other generation
This all seems to be wandering rather far from the question of when dynamic range is 'too much'.
I have a 16Kw Hi-end PA system, the pro-ribbons can go to 130db.
Its in a large studio room - a normal hi-fi would sound like a tin can in the corner in comparison.
But I only use it once a month on average otherwise its likely to cause hearing damage.
I have a set of test tracks used by audiophiles that range from classical through to 32 bit electronic music.
There seems to be few really good recordings that can take advantage of a system like that.
I have measured peaks from my seat in a large performing ensemble, sitting in front of the timpani, at 108 dB SPL A-weighted. Assuming the above scales, the quiet bits would be at about 40 or 45 dB SPLA, which seems to me about right and validates the range in my mind.
I doubt that such ranges are ever recorded as such, which is, in my view, why recordings never sound quite realistic.
Single-sample peaks are of no interest in the quest for realistic sound. The intervals over which sampling is averaged would need to match human perception, and no faster.
According to a mic company, they recorded 130 dB peaks (I suppose audible) inside a grand concert piano, obviously none of the musicians will listen that because it was directly over the strings.
Before I mentioned Vikingur Olafsson particular recordings (studio), the mechanical noises are very audible and in the Organ Sonata BWV 528 II movement arrangement recording gradual crescendo goes pretty loud.
Personally I like some hyper close recordings as I can remember when I played myself with the front of the piano leaved.
Glenn Gould recorded his latest version of Goldberg Variations with mics placed in face of the nude piano, but it said it liked the naked sound because the precision of the feedback, sound traveling from strings to head with reflections can cause some delay specially in grands.
Another extraordinary recording in dynamics is Sviatoslav Richter's Pictures at an Exibition (Mussorsky ), I don't know if is a myth or not but he broke 3 strings of the piano during the concert. The quietest parts of Promeade variations and "cum mortuus in lingua morta" passages are really low also.
Agreed in general, and the 100ms sample in the paper I cited is perhaps the shortest tone burst that a person can hear without needing to be amplified above its current level. But the histogram I cited isn't an observation of single-sample peaks, but rather amplitudes aggregated into 100ms bins from continuous music. The usual graph I recall from Alton Everest's Master Handbook of Acoustics reported the shortest tone burst (presumably in a field of relative silence--a single sample) that can be heard without needing to be amplified, meaning that shorter standalone tone bursts will not be perceived as being as loud. I'm sure there are all sorts of qualifications and limitations on that measure, but I don't recall them and I don't have the book handy.
In this picture of snare-drum waveforms...
(source: https://www.soundsandwords.io/drum-sound-classification/)
...initial impulses seem to be quite short--as little as 20 or 30 ms--plus a much longer reverberant tail. If that impulse clips, the waveform for the hit won't be as tall with respect to the reverberant tail, and that seems to me to affect the sound significantly, despite that the peak is a much shorter duration than 100ms. The difference between the hit and the reverberant tail in the third column, for example, is greater than how much the hit would need to be amplified to be perceived as being as loud.
Note that snare drum hits are one example of short peaks that are distinct from the wall of sound--potentially a single sample that does stand alone--and particularly in orchestral music, but also in quite a lot of jazz and old minimally processed rock.
(The spectral waterfalls don't seem to show the difference in amplitude very well, and sometimes I wonder if we think spectrally at the expense of looking at amplitude variations. The color variations that are supposed to reveal dynamics are not nearly as precise an indicator of amplitude as the waveform itself.)
In any case, any difference in the recording or playback and the initial signal is a distortion, and the question is how much of that dynamic distortion is needed to affect the perceived sound. So, the required dynamic range may be greater than the 75 dB range measured in the first paper I cited, because the peaks that affect it may be shorter than the 100ms bins into which they aggregated their samples. I think of it as a floor, because clearly the time period of interest isn't any longer than 100 ms. And, again, this is validated by the minimum dynamic range (as usually measured with audio--broadbanded) that I perceive as sounding "realistic".
Rick "thinking that clipping/compression happens somewhere in the recording/mastering/distribution/playback process much more often than we suspect" Denney
I personally absolutely think that too much of a good thing is a bad thing with regards to dynamic range.
My room has a noise floor of about low 40's with the HVAC on, it's probably mid 50's as the HVAC is in an adjacent room.
My ears physically cannot take high SPL, it hurts, at around 100dB, I can only do very short burst of 100dB and few and far in between. And if average is less than 65dB is my low end to have an enjoyable experience.
If you own an AVR, they virtually all have a mode called something like 'night listening' or 'dialogue' or 'dynamic volume' that compresses the dyanmic range so that you can hear both 'quite' and 'loud' parts without cranking the volume very high.
Well, have you considered cutting down on the HVAC racket with a mixture of soundproofing and acoustic treatment then? It may be hard to get rid of very low-frequency noise, but you should be able to cut down on anything above that substantially.
My personal limit is something in the low 90s peak. I could basically have a shirt made for live concerts that says "The PA is 20 dB too loud". I am using the dynamic range compressor built into Rockbox when on the go, but nothing of the kind at home.
Yeah, I did considered it, but it's not easy to do. The main issue I have a louver door to ensure no negative pressure.
Mine is probably around the same to be comfortable, once it starts to hit 100, my ears literally hurts.
The last concert I went to, we sat all the way in the back, so it wasn't too bad, but we did bring ear plugs just in case.
