I'm able to to put the single-ended into the STP and it is then converted to balanced and then out to the Peachtree.
It's the Pre Box S2 Digital.
Worth a watch
I've done quite a bit of listening to it before the S2 arrived and also tried out my older Peachtree DAC-ITx. The difference is not that subtle. In fact, I believe even someone without any experience with my system would readily tell the difference. I'm still at a loss to why. I just can't explain the loss of air and space when not using the preamp.
Do you use a preamp?
I couldn't find a spec for the output impedance of the S2 - do you have a link?
I'm not sure how I'd be able to wire that up so that it was button-switchable.
Digital volume when performed at 32 or 64 bit resolution does degrade the sound and you are rid of the issues of analogue pots.
My range hypex amps driven directly from the dac with digital volume work very well.I'm probably going to get a hypex ncore amplifier in the next few weeks so maybe I'll try out the whole preamp testing soon since I'll need to rewire anyway.
Hagagaha. Phone typingI know you meant to say doesn't there, right?
SAll things being equal, ie appropriate voltage drive levels and impedances a pre amp can do nothing to improve the sound.
It can of course add noise, distortion and colour the sound. At best a pre can be transparent.
Digital volume when performed at 32 or 64 bit resolution does not degrade the sound and you are rid of the issues of analogue pots.
S
So, if I experience a degradation without the preamp, could it just be because of digital problems? I'm using Audirvana on my mac out to the S2?
I doubt it very much. First thing you need to do when comparing is precisely match volumes. Then you need to swap between the two without knowing which is which.
As mentioned above it may be that you just like the colouration of the pre.
Hi there KirkHmm, I would like to try a blind test. I'll have to work on this. If it is colouration, I'm loving it.
BTW, I'm Kirk - I just wrote you regarding the P252. Were you able to gather any specs on that yet?
