Can someone with more experience of reading REW generated spectrograms help me decipher what is going on here? Thank you!
I guess my confusion comes from the relationship between the Peak energy time trace and the decay time. The peak at 68Hz and the corresponding decay time, for example. Why in some cases there is a delay. I’ll delve deeper and educate myself. Thanks, everyone.Just another way of looking at the IR... REW's online help:
When viewing sweep measurements in Fourier or Wavelet mode the time starts before the peak of the impulse so that the onset of the response can be seen. The areas where the response is decaying more slowly show up as streaks along the time axis. The dashed line is the Peak energy time trace which shows the peak level in the plot at each frequency. This can highlight variations in peak energy arrival versus frequency - an ideal peak energy time trace would be a straight line with the same time value for all frequencies.
Some of the modal/reflection effects show as delayed energy. The theoretical ideal is uniformly flat with the same amplitude level and starting time, which doesn't exist in the real normal rooms.
Thanks for your input. In layman’s terms it is easier to understand specific to my room. I’m new to REW and am trying to dial in my subs better. I’ve already been able to make big improvements by adjusting the cutoff frequency and the phase on the subs.If I take a look at this graph I would say that frequencies <25Hz are ringing significantly (>1 sec) compared to >25Hz
Also there is some ringing around 30-40 and 50-70Hz (around 400-600ms which I would not consider bad at these frequencies in a non-treated room)
Just my 2 cents, I might be wrong
Useful tip. Thanks!Some of it could be noise from fast 128k length sweep. I prefer using a slower sweep measurement for viewing a waterfall or spectrogram graph.
Close, 3,30 X 5,30. There are some features that make the room dimensions confusing. Here is a quick sketch. The dimensions are not 100% accurate. There is a door on the left of the diagram that goes into another room. The room on the right is the kitchen which is approx 6,00m in length. The corridor to the top left leads to a further two other rooms.is your room like 490 X 330cm?
The grey boxes indicate my speakers and subs (the larger being the subs). Also, the spectrogram with the changes in appearance as you suggested.
The black line on the leading edge of the nodes? I have manual phase correction ability on the individual subs. Would that be something I could further make fine adjustments of to make improvements? I have already made some improvement by doing this. If a software approach via plugin or other software would be a better choice, do you have any recommendations?see that black line? how it is delayed around the modes. I think a phase correction (software) can cure the worst here.
No, I don’t use any correction software other than the Voxengo PrimeEQ as a plug-in within Audirvāna. I’m willing to buy some software.these wont do it for these...as theye act on the whole. You don't use any correction software with phase correction abilities?
the sweep doesn't realy reject the noise for waterfall/spectrogram.
the only thing that works is loudness.
