Hi All,
I am experimenting with using room measurements to integrate dual subwoofers into my stereo setup. I am using REW, Dayton UMM-6, and a microphone stand. The UMM-6 was set at the listening position pointing down. My main speakers are Vandersteen 2ce Signature II couple to the floor with spikes with tilt angle adjusted to my ear height as recommenced by Vandersteen. My room is long and narrow with no back wall. It leads into an open floor dinning room, kitchen, and family room. The front wall has a big window and one side wall has a big glass sliding door. I have 4 GIK acoustics corner bass traps in the front and 2 GIK acoustics bass traps in the side walls flanking the main speakers. The subs are dual REL T9i connected to the speaker terminals of a Cary SLI 80 tube amp. Room is hard to define because back wall opens up Ito the rest of the house but it is about 23 x 11 x 8 ft.
I have experimented with various sub positions in the room. I am not fix on their current position but for now I would like to leave this variable out of the equation. The subs are place diagonally in opposite corners of the room. My goal is to learn how to use room measurements to help me adjust the level, crossover, and phase with the subs in their current location. Once I get them dial in as good as I can I will try other locations and repeat the same process.
Through out this process I also want to pay attention to see if I can actually hear differences when making acoustic corrections using room measurements. To me, this means listening to music for several days and playing different tracks.
Ok...sorry for the long intro. Please see the attached files. The blue traces show the main speaker frequency response without the subs. Red is the main speakers and both subs with rear and front sub phases set to 0. Purple is the same but with rear sub phase set to 180 and front sub phase set to 0. What I like about these results is that I see a drastic change when I switch the phase in the rear sub from 0 to 180. I am trying to decide which is better? I think 180 shows both subs in phase which makes sense considering their physical orientation. Also, the downward slope from 30 to 10 Hz seems to better mach the specs of the subs. When out of phase, the frequency response looks a little more flat, and a possible resonance peak at 15 Hz is reduce by about 5 dB.
What is disappointing, is that when the subs are in phase they don't seem to add anything new to the mains other than an increase in volume. Looking forward to your feedback.
