- Thread Starter
- #21
I got back a response from Audiophonics, they identified a bad capacitor and changed the 6 identical ones to make sure it's good. They were super fast, amp arrived yesterday, was already fixed and tested for 4 hours by today.
Acceptable but not excellent (in my opinion FWIW). The error seems to be in the DAC, and the amp is reproducing it.So I've done some DC measurements before installing the fixed amp.
DAC out
RCA 1.6/0.9 mV
XLR 3.2/2.2 mV
Amp out / speaker binding posts:
55/36 mV
Are these values OK?
What amp is it? The offset at amps is usually a little lower but some amps do run a 50mV offset by spec. Let's see if we can find a service manual.So I've done some DC measurements before installing the fixed amp.
DAC out
RCA 1.6/0.9 mV
XLR 3.2/2.2 mV
55/36 mV
Yes, after I made that comment I read the entire thread. I don't think we are going to find a service manual for that class D amp. I edited my first comment.This one: https://www.audiophonics.fr/en/powe...tereo-ncore-nc252mp-2x250w-4-ohm-p-14185.html
It was in the first post.![]()
That is interesting although it does not specify the offset voltage at the speaker terminals when there is no input to the amp. This information specified max 50 Volts at the open collector output. Not sure what the open collector output is exactly too.
To whatever the implementer wants to use for indicating a DC error. Perhaps an LED and current limiting resistor between J6.3 (standby power) and J6.7 (DC Error open collector output), or to a microcontroller pin with a pull-up resistor.This information specified max 50 Volts at the open collector output. Not sure what the open collector output is exactly too.
Since when is 12V DC into a speaker not a problem? Less than 50mV is the typical maximum. A quick and dirty DC test if you dont have a volt meter: Turn your Amp on (make sure its working) than with no signal disconnect the the speaker. Do you hear a pop or see the woofer moving? If you do there's probably to much DC out of your amp. Reconnecting the speaker will do the same thing only the woofer will move the other way.Oh... looking around online for a manual for the amp, I noticed this somewhat concerning notice on the link you posted, @hyperknot:
3) you might want to check your signal (input) source for a DC offset(?).
Your Amp could still put out a DC offset with no DC input if its faulty.I measured the DAC, playing "silence" on normal levels. DC offset is 0.2 mV.
Indeed, thus my comment that the snippet I posted was somewhat concerning.Since when is 12V DC into a speaker not a problem? Less than 50mV is the typical maximum. A quick and dirty DC test if you dont have a volt meter: Turn your Amp on (make sure its working) than with no signal disconnect the the speaker. Do you hear a pop or see the woofer moving? If you do there's probably to much DC out of your amp. Reconnecting the speaker will do the same thing only the woofer will move the other way.
@hyperknot is this amp still under warranty?
