Help deciding on active floorstanders
T
teapea
Thanks all, doesn't sound like I'm missing anything, and Dynaudio is looking like it might win out. (As much as she likes the b&o, the saved cash can go into the mid life crisis Lambo fund ). I actually used to use Dynaudio in the car back in the days I used to compete in SQ - blast from the past, doubt that even exists any more!
I guess I'd like more info on the Piega option. This could be a cheap alternative and the fact they do it in white and they're small has appeal.
T
teapea
Don't you just want a WiSA hub and then any WiSA certified speaker will do so long as they meet WAF/PRICE/PERF?
Yeah that's the problem, getting the balance between all those, when the options are very limited and wildly disparate in pricing... And a wife with expensive tastes
eddantes
Well... AFAIK Kef LS60s are ✅ for WAF/$/PERF(no sub needed) ... you'll just need to add one of these for each side
https://www.av-connection.com/?PGr=17281 and the aforementioned hub.
Adds quite a bit of cost though and I don't know about the performance.
Another candidate to consider is https://www.davoneaudio.com/wireless.html WAF through the roof
