1.5 watts out of the JDS El Amp I would consider to be the minimum for the HE560.Too bad I just missed the THX AAA massdrop. I could get the monoprice one but I don't really want to buy something without seeing the reviews/measurements. Do you think JDS El Amp will work okay with HE-560?
Also I think age should be considered, what is considered piercing may not effect me the same as a younger person. I can handle the very high end cause I dont hear it anymore. (above 15k)1.5 watts out of the JDS El Amp I would consider to be the minimum for the HE560.
JDS El Amp sounds like a decent choice, low output impedance so I'm not limited to only high impedance headphones. Do you know any reviews and measurements of this unit? I like graphics and numbers.
It goes hand in hand with the "headphones scale with amps" meme pervasive in the audiophile community.I'm always fascinated about discussions of "hard to drive" headphones.
You have got to be kidding. Driving cans at 1. 5 Watts!1.5 watts out of the JDS El Amp I would consider to be the minimum for the HE560.
No, to run it at the lowest THD!You have got to be kidding. Driving cans at 1. 5 Watts!
Which has nothing to do with the ultimate output power I'm afraid.No, to run it at the lowest THD!
I'm always fascinated about discussions of "hard to drive" headphones. Headphones only require, at worst, a few tens of mW to drive them to daft volume levels. This isn't difficult to acheive in any way to very low (amp) distortion levels.
However what is required is an appropriate output voltage from the amp to suit the impedance of the cans. Generally higher impedance will need higher voltage.low output zshould always be sought.
I wouldn't return your Lyr3 just yet. I have a Lyr2 and I like the way it sounds with the HE560 quite a bit. If you don't like the Multibit DAC card that came with it, just get a D30, or any other DAC with line out and try that.Any other recommendations besides the JDS El Amp? I don't think A30 is a good choice due to the high internal impedance.
