Hey guys, first post here.
I have a pretty simple requirement for a high quality headphone amp that will only receive input from a phono stage. It's just to be used for listening to vinyl on headphones without any DAC conversion or other components getting in the signal chain. The only caveat is that the space is really tight so the amp would need to be smaller than 150mm wide.
My cans at the moment are AKG K712's which I've used in the past for mixing, but will probably get a more suitable pair for dedicated music listening.
I've looked at the SMSL SH-6 which appears to check the boxes but apparently has quite a thin sound stage. So I'm looking for recommendations of the best quality headphone amp that'll squeeze into a tight space. Budget is sub $600.
Thanks in advance!
Thanks in advance!
