egothrasher
- Joined
- Jul 17, 2020
- Messages
- 32
- Likes
- 11
I could use some help clearing up some confusion. From what I can gather, unbalanced cables are your 3.5mm or 2/3 pole cables. Balanced cables on the other hand are your xlr, 4.4mm trs, anything with 4 poles/sleeves.
Just got my he4xx in the mail, they sound amazing and burning them in. But there is no way to have balanced cables with this setup I am assuming. The headphones have 2x 3.5 mm inputs. Even if you had the other end of the cable be balanced, say the 4.4 or xlr, it wouldn't matter because the other end plugging into the headphone themselves is 3.5, correct?
If you have balanced end going into unbalanced end, I would assume that makes the whole cable unbalanced and probably cause problems, or does it cause problems the other way around?
