ninetylol
- Joined
- Dec 7, 2019
- Messages
- 692
- Likes
- 661
Everything seems fine more or less. Still stuttering.You might as well try and check your computer latency / DPC with this program Latency Monitor
Did not work for me, still stuttering. :/So I had a similar issue while using exclusive mode on Tidal and Amazon music, where the x16 will cut out and stutter. I was able to resolve this by changing the latency in the X16's driver settings. The issue I ran into was that the latency setting for tidal did not match the latency setting for Amazon music. After a ton of frustration I figured out that if I disabled the setting in windows for allow exclusive apps to have priority, that it fixed all the problems with Tidal, and 80% of the problems with Amazon. Since Amazon music doesn't have a true exclusive mode I just leave it off on Amazon, Unless I have all other windows capable of playing sound turned off. This isn't so much an issue with the X16 as it is an issue with exclusive mode. All my other DACs were cutting out whenever you enabled exclusive mode in any streamer. It doesn't seem to want to play nicely with other windows that can play sound like YouTube. Disabling that setting in windows will fix most of your issues with exclusive mode though.
Did not work for me, still stuttering. :/You can try, increase Buffer to avoid stuttering.
EDIT: The X16 seems to be working on exactly one USB slot which is my separate PCIe USB 3.1 card, which is noisy af though (tested a year ago with Loxjie D10-> i could hear my graphics card coil whine and mouse movement through that USB slot.)
