SB15NBAC30-8 5" Black Aluminum Cone Mid-bassNew Black Aluminum cone from SB. The cone is crimped in four spots for additional stiffness. Smooth upper midrange especially off-axis. Vented cast aluminum chassis for optimum strength and low compression Geometrically reinforced aluminum cone for...
www.madisoundspeakerstore.com
Also available in 4 Ohm. Used by Revel:
This is a review and detailed measurements of the Revel M105 Bookshelf/stand-mount speaker. A member was interested in it so I decided to buy it through our company. The retail cost is US $750 each for a total of $1,500 for a pair. NOTE: my company, Madrona Digital is a dealer for Harman and...
audiosciencereview.com
It is tested and measured here, FR on and off axes, distortion levels at different power levels:
The THD measurements at distance of 20 mm and voltage levels from 4 to 5.6 Volt were carried out with High Pass Filter "on" (4th order Butterworth type, 20 Hz cutoff, HPF4-20). The THD measurements at distance of 315 mm and voltage levels from 2 to 4 Volt were carried out with High Pass Filter...
hificompass.com
Copied here, see also page 4 in the thread where the element is used in another DIY as a midrange driver:
I'm trying to have the waveguides printed by materialize.com - however, the STL file does not get imported in the right scale and I need to manually have it scaled up. Does anyone have the right measurements for the waveguide?
The slightly larger variant with ceramic coated surface:
This is used by many. Incredibly good sound, performance for that price.
Just think of relatively low sensitivity. When to match it with other elements:
Taking in account the high technical performance and very low cost, TC9FD18-08, in my opinion, is just incredible speaker!
The THD measurements at voltage level 2.83 Volt were carried out with High Pass Filter "on" (2nd order Butterworth type, 80 Hz cutoff, HPF2-80) The THD measurements at voltage level 4 - 11.2 Volt were carried out with High Pass Filter "on" (2nd order Butterworth type, 150 Hz cutoff, HPF2-150)...
hificompass.com
Another tip (which I now see that alex -z has already tipped about):
The THD measurements at distance of 315 mm were carried out with High Pass Filter "on" (2nd order Buttreworth type, 300 Hz cutoff, HPF2-300)
hificompass.com
The realism of the mids with the RS52AN is astounding. It's not simply the clarity and transparency. It's fast. The attack of the voices and instruments must be heard to believe.
