Thanks for the answers. Does the hiss get lower if the sensitivity is turned to the lowest setting?
Input sensitivity is set at highest -6 which is default.Thanks for the answers. Does the hiss get lower if the sensitivity is turned to the lowest setting?
Which dac is used to drive the speakers ???TL;DR: Here is a picture comparing the size of an 8030C and 8020D on a 30" desk. I am posting this in case anyone else is concerned about the physical dimensions of the two models. I found it hard to find images of the monitors on desks when I was doing research.
Two weeks ago I ordered a pair of 8020D with the matching Genelec (K&M) stands. I was intrigued by the 8010A but wanted something a bit larger with deeper bass extension. I had considered the 8030Cs but was afraid they would be too large looking on my desk. Over the last seven or so years, I've had pairs of PSB Imagine XB, KEF Q100, Audyssey Lower East Side Media, and Dynaudio BM Compact MKIII on my desk. For the last three years, I've been running a pair of Peachtree Audio DS4.5 with a Parasound Zamp v.3. After recently running into some issues with the Zamp, I decided to try a pair of active monitors.
The reason I'm writing out some of my speaker history is that I've had small and relatively large speakers on my desk. At this point in time, I'm looking to avoid having 12" or 13" tall/deep speakers taking up lots of space on my desk. Also, I don't love the look of large speakers flanking my monitor. In a future desk set up, I could see getting larger monitors and putting them on stands behind a desk.
Anyway, after a day of testing the one 8020D that was shipped to me (the other hadn't shipped), I decided I could handle a slightly larger monitor. I also had some buyer's remorse as the 8030C is supposed to be the most popular model, and the 8020D seemed a bit forgotten between the 8010 and 8030. I canceled the 8020D that hadn't shipped and placed an order for a pair of 8030C–also with the matching/corresponding stands.
As I already had the 8020D on my desk, I figured I'd compare the two sizes. Here's a picture of both on my desk. Because Genelec monitors seem to have relatively shallow physical depth compared to many other active monitors, and have rounded edges, I think the 8030Cs are a great size on a desk. Not too big, not too small.
Once I get my stands in a week or two, and have some time to really test the speakers, I'll post a review of the speakers.
Sure, but if you use the lowest, -12dB, does the hiss get lower?Input sensitivity is set at highest -6 which is default.
The range is +6 to -6dBu. +6 is for hottest input. -6 is the highest (lowest in number). There is no hiss in my samples.Sure, but if you use the lowest, -12dB, does the hiss get lower?
I use +6dBu, because it is already very loud. I don't know if hiss gets worse if set to -6dBu, never tried.Sure, but if you use the lowest, -12dB, does the hiss get lower?
Perhaps your power grid is cleaner than mine. Just plugging one 8030C on any outlet of the flat, I get the same hiss level, even without anything connected to the unit. It doesn't get worse when I plug my DAC (Topping E30).There is no hiss in my samples.
I don't know what's the optimal input sensitivity for genelec. I just don't trust its internal attenuators. For desktop usage, I am using a pair of u-pads (-30dB) built from high quality parts along with digital/software volume control(within 10dB).I use +6dBu, because it is already very loud.
Hiss was the same with inputs connected and disconnected. I don't rememeber if input gain affects hiss tough. I was using the lowest because at default speakers were too loud.I ask all this to understand where the hiss is being generated from. With the unit disconnected from XLR input:
- If be reducing sensitivity to the lowest setting reduces hiss, then the gain stage is noisy.
- But if increasing or decreasing sensitivity does not alter hiss, then the gain stage is clean and the power stage is noisy no matter what and nothing we can do about it.
How are you liking the 8030C so far?
JBL LSR310S or Yamaha HS8S.Yesterday I paired my five-year-old Audioengine S8 with my 8030Cs and it adds some welcome low end. That said, I have long been meaning to sell the S8 on Craigslist and would like to get something higher end for use with the Genelecs. Can anyone recommend a sub based on the criteria below? A few weeks ago I read through this whole thread, but I'm forgetting if or when sub recommendations were made.
Use: Nearfield at my desk. 90% music, 10% gaming
Budget: $300 to $800
Size: Prefer something on the smaller side as it will be under or next to my desk.
Miscellaneous:
The Genelec 7040A could be the way to go but it only has a 6.5" woofer. Will that effortlessly produce enough low end compared to the 5" drivers in the 8030Cs? The Genelec is probably a good match to the 8030C because it's the same brand. I don't want to spend the extra money on the 7050C, and that sub also has an overwhelming looking amount of XLR inputs and outputs given that I'm using this in a simple 2.1 setup.
- Sealed? A sealed sub might be smaller and I don't need crazy deep extension.
- Anything with a high pass filter so I can free up the 8030Cs to focus on higher frequencies?
- I don't need or want that much bass, but I still like the idea of a sub with a larger driver in case I want to repurpose the sub in the future.
- I am open to a "studio" or home theater sub. I am currently using my 8030Cs with XLR to RCA adapters, but that could change if I switch to a Motu or or Audient interface in the future. That might mean it would make more sense to look at subs with XLR in/out.
I am considering the new SVS SB-1000 PRO. It is small given it has a 12" driver, is at a nice price point, and has a great warranty. The sub would only have RCA, but I'm fine with that. It also doesn't seem to have a high pass filter, but that might be harder to find.
Thanks for any recommendations!
For reference, I've got mine on stands behind a 2-meter wide desk, and about 1 meter each from my listening position. I haven't found them too daunting in size, but I do admittedly have a large desk.
All in all, I've been really thrilled with the sound these things can produce, and I've been dumbfounded by just how loud these things get. I have them running through an SMSL SU-8 via a Little Bear, and hardly ever have the dial set past 9 o'clock.
I will say they are sensitive to placement though; since getting them I've added homemade foam pads around my room and run calibration with REW, both of which have made significant sonic upgrades, as at first I was not impressed with them out of the box.
I've been toying with the idea of upgrading the DAC (to a Topping D90) or throwing in a sub, but given that my room is only 14m² and the SU-8 already has a SINAD of above 100, I'm doubting either of those would actually add any audible benefit
Could you elaborate why these two are better choice than SVS 1000?JBL LSR310S or Yamaha HS8S.
Cheaper, low pass AND high pass filters.Could you elaborate why these two are better choice than SVS 1000?
Non pro version do have low&high pass filter. I thought svs are the best becuase they measure flat and that's what we want right?Cheaper, low pass AND high pass filters.
