Focusrite Scarlett
Ole_S
Hi people,
Yes, it is me again.
The annoying person from Denmark.
I am just curious to hear your opinion on Focusrite Scarlett.
Jesus, some reviews!
Your thoughts on the brand and its products?
Especially:
  • Foscusrite Scarlett Solo 3rd Gen
  • Foscusrite Scarlett 2i2 3rd Gen
I am pretty sure you do not like Focusrite Scarlett, but know knows.
Looking forward hearing from you.
// Peace
Apesbrain
East Coast, USA
Keith_W
Melbourne, Australia
Whether or not you like the Focusrite Scarlett depends on what you are using it for. I have a 2i2 that I use with REW and a calibrated mic for room measurements. In this role it is fantastic - no fuss, easy to set up, and reliable. Mine is a Gen 1 2i2 and it still works flawlessly. OTOH if you want to use it as a headphone amp, be aware that the output is very low. As a general purpose DAC it will probably be OK.
Hexspa
They’re high quality devices with good support and excellent bundled software. I can’t comment on the drivers but they’re probably well-wrung given their wide adoption.
Hexspa
Gen 1 is a worse performer than subsequent generations but it seems like the more experienced users don’t mind the difference.
O
Ole_S
Thank you for replying.
Better than Topping in our
Very useful.
Thank you.
Keith_W
For the 2i2, and for me, the drivers work flawlessly. Download, install, plug in, and the device is recognized. No problem. Amazon reviews gives it 4.7/5. But Amir recently did a review of the 18i8 here and he complained of BSOD's and the device refusing to show up on his PC. Looking back at those Amazon reviews, there were 3-4 complaints about the driver (out of 37,000 ratings) so driver issues for the 2i2 are probably a rarity.
Barrelhouse Solly
I've had one for over 10 years. I've used it for home recording, room measurement, and as a usb DAC. It has been reliable and, like a good DAC, it's seen, not heard.
Ricardus
Northern GA
I have a 2i2 and a newer Claret+ 8 Pre and they work flawlessly, and I'm running them under linux,
Matias
São Paulo, Brazil
3 years ago I learned how to do a loopback measurement of my 2nd gen 6i6 below. Most impressive was the low distortions when using with "normal" volume levels like volume knob at 10 o'clock.
DVDdoug
I don't own it but MOST of these "little audio interfaces" from various manufacturers are very good for their intended purpose (recording from microphones, guitars/instruments, and line-audio sources).
If you have some special or unusual requirements you might need to check the features & specs.
Yogevs
I had the Foscusrite Scarlett 2i2 3rd Gen for recording and monitoring with speakers and headphones. It's a really cute and well-made device. My only problem with it was that when the headphone volume passed 75% it didn't sound amazing (for recording it was still fine, but not for listening/mixing). So if you use non-efficient headphones or EQ your headphones, I'd skip it. Otherwise - highly recommend.
Ricardus
Northern GA
This was a common complaint and I guess in the newer Clarett series they improved that.
Matias
São Paulo, Brazil
For a time I used mine with digital out to a DAC+headphone amp, so I got the best of both worlds (home studio recording + audiophile powerful amp).
khensu
Colorado
I have the 2i2. No idea what gen it is, but I only use it for recording streams with Audacity. I also noticed the headphone output isn’t the greatest, but I don’t usually use it. It’s a great device otherwise; no complaints from me.
