Filter quality
Doobrey
Do DAC filters have an impact on how we perceive treble quality?
For example would a filter with poor attention let in more aliasing and create a harsher sound?
Hayabusa
Abu Dhabi
Depends on how the rest of the audio chain after the DAC handles the alias signal.
In theory it could increase inter modulation distortions that fold back into the audible range.
Also a speaker(tweeter) could not handle the extra high frequency energy correctly.
But if all components after the DAC are 'perfect' it should not be audible.
Doobrey
Doobrey
So let’s assume the rest of the chain was perfect, a “chord like” filter would be the best for the smoothest cleanest treble?
NTK
US East
No. A reconstruction filter with poor attenuation simply means there may be more ultrasonic "garbage" above the Nyquist frequency.
Doobrey
Doobrey
When those artefacts fold back in to the audible signal what does it do to the sound?
JSmith
Algol Perseus
JSmith
HarmonicTHD
Mainly nothing as with SOTA DAC filters are not a concern and the distortions are by orders of magnitude below audibility. To be specific: pick a DAC which was measured here and look at the multi tone test.
And the filters from the Chord company are not any better (or worse). It is just a myth the company likes to uphold to sell their products. It has been analyzed here many times.
voodooless
Netherlands
Those are at 192 kHz, but bandwidth shown is only 20 kHz. Nothing about the reconstruction filter can be gleaned from that.
NTK
US East
The D-to-A reconstruction process does not produce aliasing (fold down in frequency). I had been mistaken about that before too.
Look at D-to-A as a reverse of the sampling process. When you have components above the Nyquist frequency in the sampled signal, they alias into frequencies below Nyquist. In the reconstruction process, the signal below Nyquist "image" to frequencies (at Fs ± f, 2Fs ± f, 3Fs ± f, ... etc,.) above Nyquist.
DonH56
Monument, CO
ADC conversion can produce aliasing of signals above Nyquist (half the sampling rate) frequency back into the signal (base) band. DACs produce images that lie above the Nyquist frequency and do not fall back (alias) into the signal band. A poor anti-imaging filter can add more high-frequency content that is objectionable, though remember it is usually above (often well above) 20 kHz so may not be audible. It could dump more power into your tweeters; whether it would be enough to cause damage seems unlikely, but not something I have really analyzed.
My signature has a link to a post with a listing of articles showing ADC and DAC operation if you want to understand aliasing and imaging better.
Doobrey
Doobrey
So a filterless nos DAC won’t add junk in to the audible range?
voodooless
Netherlands
Not junk, but they cannot reconstruct high frequencies properly. The HF droop is only half of the story.
So what it can do is modulate high frequency content with a lower frequency. This may very well be audible in some cases. Though with real music, you’ll probably notice the frequency response error much more than the modulation.
NTK
US East
Here is a very quick description of the D/A process (with no oversampling) from Chapter 3 of The Scientist and Engineer's Guide to Digital Signal Processing.
The "filterless NOS" conversion represents only the top 2 steps in the left ("a" and "c", time domain) and right ("b" and "d", frequency domain) figures. "Filterless" is a misnomer. The zeroth-order hold conversion (= sample-and-hold stairsteps, as shown in figure "c") is actually a convolution of the digitized samples in the form of an impulse train (figure "a") with a unit square pulse. In the frequency domain, it is the spectrum of the digitized signal multiplied by the Fourier transform of the unit square pulse, which is the sinc function (spectrum of the stairsteps = the product of the 2 curves in figure "d"). Therefore, the sample-and-hold stairsteps actually are the results of the digitized samples filtered by a filter that has a frequency response that looks like a sinc function.
To correct the frequency response errors of the filtering by the sample-and-hold process (and to remove the residual "junk" above Nyquist due to the incomplete LP filtering), the stairsteps needs to be filtered by a filter with the response that is shown in the right side third from figure "e" (the "ideal reconstruction filter"). After this filter, you'll have the proper analog signal reconstructed (figures "f" and "g"). Without this second filter, the filterless NOS produces a non-flat frequency response in addition to the inadequate removal of the "junk" above Nyquist.
Hayabusa
Abu Dhabi
Indeed D/A creates the images/replicating spectra but any non linear process after this can cause parts of these images fold-back in to other (also audible) frequencies.
