THANK YOU !!!!There is zero logic in replacing that cable with another expensive one.
You will gain nothing, only lose money.
No
Thank you.
Thanks for accepting me !Hi @ronorn
Welcome to ASR. Please stay, it can be a bit arduous and often some of us (pleading guilty) at times are a bit .. curt... If you are a music lover and an audiophile, staying and learning here at ASR, will not only save you a lot of money but will result in you getting the best sound you could have ever for your heard earned money.
This said for Audio purposes, You don't even need a Cat 5e... Cat 3, an old type of cable you could find in building, would have worked and well... but Cat 45 is , now hard to find so ANY decent Cat 5 cable would do and that on much longer span... 100 meters/330 feet is what the standard recommend but I bet it would work on twice this distance .. Yes.
As matter of fact.. Gigabit Ethernet will run reliably on , yes, barbed wires. (Click Here)
Now you mention that you have a "good" streamer, a Lumin and I would suppose, you paid some good money for it... since the least expensive Lumin, the D3 has a MSRP of $2700... I suggest to you an experiment: Acquire a Wiim Pro streamer about $150 at Amazon. Plug it in your system. Try to match the levels with your smartphone. Report to us...
Peace.
HiThanks for accepting me !
Also thank you for your ethernet explanation.
Regarding the Lumin streamer. I have the U2 (Not the Mini) , Replaced the bluesound NODE with the Lumin.
According to my ears. HUGE improvement. (even if technically not - I enjoy more ) that's what important to me.
I have a short run of the AQ green cable. It was what the store had, and was not too expensive. I was in a hurry. AQ calls it Forest. I guess because it is green. I can safely report that it works. So it's got that going for it.Is there any logic to replace the cable with another expensive one?
Like AudioQuest or similar?
I would advise you to not believe in your ears so much. These are easily deceived. But it's that is what you want to believe ...
Perhaps I could suggest a different, more expensive, experiment..
yes, throw that inflexible thick cat8 to trash and just use plain cheap cat6.At that length, a regular cat 5 cable would work just as well.
Well, no reason to go to that extreme. But, yes, CAT5e would have been fine.yes, throw that inflexible thick cat8 to trash and just use plain cheap cat6.
Plus, after a few drinks, you'll start to hear that front to back depth you've always known was missing.![]()
MY opinion only : They believe that cable is with less outside interferences than wifi.It's quite interesting that this very expensive Lumin U2 streamer doesn't have Wi-Fi....
I guess it's High-End audio in a nutshell : higher price tag gets you less functionality.
