Chris Kelly
- Joined
- Nov 4, 2022
- Messages
- 88
- Likes
- 11
Do any multi-channel audio/video receivers do this? It would solve the problem of DSD getting converted to PCM, as well as 192KHz PCM getting downsampled.
...and create tons of new problems, much worse than the ones it would solve.It would solve the problem of...
I can't hear DSD to PCM conversion. I can't hear downsampling from 192kHz either. Am I missing something?Do any multi-channel audio/video receivers do this? It would solve the problem of DSD getting converted to PCM, as well as 192KHz PCM getting downsampled.
Good question. OP, just what are the problems you're solving?I can't hear DSD to PCM conversion. I can't hear downsampling from 192kHz either. Am I missing something?
We know the opposite ways of thinking since DVD-AUDIO came out in the late 90s and SACD in the early 2000s. some people feel digital audio above 44.1-48KHz isn't necessary being that we can't hear above 20KHz. Some people either can hear above 20KHz and feel either that 96KHz sampling and above, as well as DSD, insures stability within the 20Hz-20KHz spectrum, or else provides overtones above 20KHz. The purpose of this thread is not to discuss schools of thought. There are plenty of threads on the internet where that takes place. I just thought EQing in the analog path might be a way of maintaining high-resolution frequency responce without compromising it.Good question. OP, just what are the problems you're solving?
You're right, the hi-res stuff is discussed elsewhere. But as I said analog EQ is a beast: tough to adjust frequency, tough to change Q, tough to change the magnitude.We know the opposite ways of thinking since DVD-AUDIO came out in the late 90s and SACD in the early 2000s. some people feel digital audio above 44.1-48KHz isn't necessary being that we can't hear above 20KHz. Some people either can hear above 20KHz and feel either that 96KHz sampling and above, as well as DSD, insures stability within the 20Hz-20KHz spectrum, or else provides overtones above 20KHz. The purpose of this thread is not to discuss schools of thought. There are plenty of threads on the internet where that takes place. I just thought EQing in the analog path might be a way of maintaining high-resolution frequency responce without compromising it.
Understood. I just thought it might be a way of maintaining the better frequency response of high-resolution audio formats.You're right, the hi-res stuff is discussed elsewhere. But as I said analog EQ is a beast: tough to adjust frequency, tough to change Q, tough to change the magnitude.
Modern digital (meaning, the last 15 years for domestic use) is just superior to analog methods. Digital in recording studios was superior even in the nineties but was still way too expensive for home use.Understood. I just thought it might be a way of maintaining the better frequency response of high-resolution audio formats.
I generally agree about DSP=easy and the right way,I use it myself.You're right, the hi-res stuff is discussed elsewhere. But as I said analog EQ is a beast: tough to adjust frequency, tough to change Q, tough to change the magnitude.
Software bug?I generally agree about DSP=easy and the right way,I use it myself.
On the other hand I always wonder about a glitch (which happen way too often as I read,nearly every day) that would add the +15db @30Hz which I usually cut.
Compromises I guess.
The more I read the more I'm convinced that to find rock solid software is pure luck or I don't know what else.Software bug?
Testing can be expensive and time consuming. Hence, it's often minimized.The more I read the more I'm convivced that to find rock solid software is pure luck or I don't know what else.
