Thanks to @Jbrunwa for the heads up on this as the info validated some crazy stuff I was hearing with my Emotiva processor. Not sure which of their AV product line are affected (I believe its only Gen3) but I know for sure my XMC2 is, unfortunately.
It appears some gremlins in the processor are applying somewhere between a 3 and 10 boost to bass frequencies (one example showed more than 20db) when using the processor's internal bass management. The range is dependent upon a number of things including size of speakers, audio mode, xo's, number of subs, etc. Due to the number of variables and the fact its in its early stages, there are no fixes and Emotiva is just now finding out about it thanks to someone who did a lot of work testing a bunch of different scenarios (see chart below) and posted on their forum. Emotiva has yet to say anything publicly and when speaking to them about it, at least they do acknowledge there is a problem but have no idea what's causing it, how long it will be until its fixed or even provide a temporary solution. There response to this has dimmed any possibility for me to buy anything of theirs in the future. As we all know its not about having problems (as that is just normal SOP in this business) its how you address them and take care of your customers (immediately think of the best example of doing it right which is how @JohnYang1997 does business)
In case you are wondering ... No, its not a Dirac issue nor can it be fixed with Dirac. If you think you may be affected or if you are interested to find out more since i am just scraping the surface of detailing the problem, you can go to their forum (i think you may have to sign up) and go to this link
https://emotivalounge.proboards.com/thread/58985/g3p-elevated-bm-lfe-issue
After a huge spike when i first became aware of it, I am now hearing weird output out of my subwoofer. It may have been overdriven and damaged it. But I asked Emotiva on who i should be talking to if i need to get it fixed and they ignored my question. I thought the elevated bass i was hearing was caused by a coincidental dirac re-configuration I did.
