Hooked up a PC to measure at 384k. What is it that you see at 88k? Different than below?
Thanks for this. I'll PM you
How did the OPA1656 perform in your tests?Guys, for about a month I wasn't able to do my work and APU/Scaler designs were delayed as well. The reason is the same that makes many of you wake up and every morning check the news about Ukraine where innocent people suffering under putin's aggression.
Anyhow, I am close to the final version of both these products and want to ask your opinion regarding the APU notch performance. At the moment I have the choice to make APU 1kHz notch with -145db/-160db or -150db/-150db 2nd/3rd harmonics resolution. I did ask that in our discord and as I see people prefer the -150/-150 version.
This is about the opamp choice, OPA2156 makes -145db/-160db, Chinese opamp RT6863/SGM8261 -150db/-150db(less OLG and worse linearity but better input stage symmetry vs OPA2156) and a lot cheaper. Of course, I tried OPA1612 as well, some of them gave -148db/-155db but 2nd harmonic is noticeable varies from chip to chip, and I don't like the idea to test at such nanovolts levels each unit. 10kHz notch -130/-130 at least both variants. Please, let me know what do you think about that choice.
The green plot is a passive notch with corrections -50db for the 2nd and -54db for 3rd harmonic i.e. -158/-161db.
The yellow plot is APU result, the correction is -30db for all harmonics(its notch is active) i.e. -150.53/-151db.
And APU with OPA1612.
What about trying this composite combination?Guys, for about a month I wasn't able to do my work and APU/Scaler designs were delayed as well. The reason is the same that makes many of you wake up and every morning check the news about Ukraine where innocent people suffering under putin's aggression.
Hi Ivan, I like the -145/-160 version.Guys, for about a month I wasn't able to do my work and APU/Scaler designs were delayed as well. The reason is the same that makes many of you wake up and every morning check the news about Ukraine where innocent people suffering under putin's aggression.
me too but chinese opamp is 3-4x cheaperHi Ivan, I like the -145/-160 version.
Question: are those op amps using the same circuit? If that's the case, people can just swap the op amps to the ones they preferred. You can just use the cheapest one by default and let DIY users do the rest. Leaving a socket there is even better.me too but chinese opamp is 3-4x cheaper
So I'd suggest just leave sockets and cheap op amps there. customers can do whatever they want.DIYers can do that indeed.
Impressive, never got the 2nd and 3rd so low with any source, even while changing chip temperature.@IVX Today l made again measurements with my grade A Cosmos ADC. The measurement is without notch filter. I played arround with temperature to Cosmos ADC and Victor's generator. Unfortunally l had no thermometer connected. I am waiting that your Scaler will be available to be able to measure lower level signals. By the way, the input range of Cosmos ADC was setted to 3.5V and the output resistors of Victor's generator are shorted. Output voltage of Victor's generator was 2.78 V RMS
Those formats are similar enough that you'd still get a seemingly valid signal, though the sample values would of course be garbled.
I would pick -145dB/-160dB too, but that's right that a solution to be able to change opamp and also used -150/-150 would be great....
It is grade-0 usually but sometimes, users report that SNR is lower after they got the unit. I did not realize what happens but ES9822 does that from time to time. So, I believe fluctuations may go on the opposite side too, and measured here grade-A in your hands becomes grade-0.Own noise level of my Cosmos ADC was -129 dBA
