"Come here to have fun, be ready to be teased and not take online life too seriously."
Just pulling your leg my friend, you weren't supposed to take that seriously.
The wink emoji is useful at times.
What your experiment proved is that this particular AD/DA procedure held up the perceived quality down to 8th generation. Not that the process is lossless or best possible. That's the job for any pro equipment: make the perceived quality good enough (not the best possible) through many generations in a production.
I understand you did not compare different AD/DA technologies, like a phone DAC to a Mytek. Or delta-sigma to multibit.
From the fact that noise build-up over generations was not perceptible does not follow that the original noise level could not have been differentiated perceptually from that of other devices. Say you do SFX generations on standard definition video. The perceived quality will hold up.Never said it was lossless. For once thru playback it is best possible, because the effects are below audible detection. Nothing of higher fidelity will sound different. I also have done similar things with phone DACs and laptops.
Good article. It scientifically describes my lay experience. I even understood the Fast Fourier Transform section! And they apparently answered my prayer from post #381 for a format agnostic AD/DA! I have some Adams in my day job and might get this Hedd thing too.back to the 8Cs with dsp?
yesterday our friend oivavoi gave a link on a very interesting company hedd audio (ex adam audio )on the very complete site there is a blog with a very interesting article on the DSP (below) what do you think? What do you say to the conclusion?
To DSP or not to DSP – that is the question http://www.hedd.audio/en/dsp-not-dsp/
It can also be of a higher quality.One may argue, in fact, that HEDD's way of doing it - DSP linearization by external computer software, not by an inbuilt mini-computer - is more future proof than the way of D&D and Kii, which may be more prone to computer failure and lack of support in the long run.
Like ASR.com?
Hmm.... Have they changed their mind lately, since the publication of that article? Now they offer a computer plugin which uses DSP to "linearize" their speakers, well described here: http://www.hedd.audio/en/hedd-lineariser/
I think it's important to keep in mind that manufacturers usually keep doing what they have been doing, because that's what they really know how to do. Most car makers keep on making primarily fossil cars, even though it's clear to everybody that electric vehicles are the future. But EVs require a completely different skillset, which can be difficult for legacy carmakers to acquire.
Similarly, to make DSP speakers requires skills in not only acoustic speaker design, but also software and computer stuff. It seems to me that HEDD audio - created by an industry veteran who has been making excellent analog monitors for a long time - has kept on doing what they really know how to do, to make cracking analog monitors. Still, they have begun to offer the DSP plugin as an option these days, and actually seem to recommend it.
what hedd audio has chosen to do today may be for economic or marketing reasons, but does not solve the problem or rather does not answer the question .
the question and to know if the double or triple conversions according to whether one attacks the dsp in analog or digital can harm the quality of the signal?
it says""
"" in most cases two additional A/D or D/A conversions, sound quality is affected""
are there any measures? tests?
other questions? how does the 8c internal dsp not generate noise on the signal? with everything inside (power supply, etc etc)
again, are there any measures? in the absence of proof doubt is permitted.
fred
Noise etc: I'm very sensitive to noise. I like stuff that is dead quiet. With electronics, from lamps to computers to refrigerators, I always choose products which make absolutely no noise. And the 8Cs seem very quiet to me. With the gain at -10 decibel (fairly loud), I can hear a low hiss when I put my ear 30 cm away, and nothing farther away. With the gain at -20 decibel (normal listening for me), I need to move my ear as close as 15 cm from the tweeter to hear anything. With the gain at -25, I can't hear it at all.
when I was talking about noise I was talking about electrical insulation not fan noise or db .
amir here on another wire says "You may have the best DAC clock in the world, but if you let the noise bleed into its power supply or even couple it through the air, you always end up with noise and distortion on the output of your DAC"
thank you for your answer even if there is still doubt, this morning I had naively hoped, that someone here would take it away from me .
It would be rare that DSP works directly on the original source data stream. Sampling/depth will most likely be different.Most people today use digital sources. One can send the digital signal directly to the 8Cs, that's what I do.
it says""
fred
