Hi, found a video review with measurements of Douk Audio U3 on YouTube, the video is in Italian, but the English subtitles seem ok'ish.
First off the original video by "HiFi Cheap".
If it is ok, I will post some screenshots for discussions sake.
My own experiences with the device at the end.
Douk Audio is supposedly a subbrand of Nobsound. Recently those amps also been sold rebranded as Cadisi X2-U301.
The official price is $41.99, the actual price online is around $22-30
Product page specs
Output power - >=1300mW @ 32Ohm
Headphones impedance - 18-600Ohm
Frequency response - 20Hz-30KHz
Signal to noise ratio - >=110dB
Max output amplitude voltage - 25Vpp
Input DC voltage - 5-20V
The description says the device takes anything between 5-20V and internally always work at 26V, uses socketed TI NE5532P OpAmp, and "using 1300mA large current output transistor working in class A"
doukaudio.com
The DC input is a 2.5x5.5mm barrel plug, and the amp comes only with a short barrel plug to USB A cable.
Frequency response measurement
Distortion with switching power supply
Distortion with linear power supply
IMD
Power output
I've seen a comment on Amazon's product page where someone claimed to measure power, I have it written down, but unfortunately can't find the comment anymore
10Ohm - 420mW
33Ohm - 509mW
82Ohm - 396mW
240Ohm - 192mW
620Ohm - 84mW
So while not exactly the same, it is close enough, and shows the same behaviour whereas power at 32Ohm is far below (4-4.19Vrms) claimed 1300mW (6.45Vrms), however it gets more in line with higher impedance loads. That said the output voltage at 300Ohm load calculates to 7.08Vrms and 7.20Vrms at that 620Ohm, which is again a bit short from 25Vpp which is 8.9Vrms. Would still call it "decent", no idea why the brand feels like they need to lie.
The YouTube reviewer also mentions he had tried feeding U3 with higher voltages and found no changes. As for my experience I also haven't heard any audible difference when feeding U3 with higher voltages, actually it seemed like U3 was heating up more at higher input voltage so I returned to using it at 5V.
As such I'm powering U3 from 5V 2A mobile phone chargers branded Samsung and Xiaomi. There is no audible noise present when using those. Trying to power it from any USB host device results in considerable noise, be it desktop PC or mobile phone. Likewise I've tried a few 12V PSU's, mostly high powered laptop and camera ones, and most of them were noisy.
I own 2 units of U3. Bought one around 2021 as a cheap amp for also cheap Sennheiser HD430 (600Ohm, 94dB/mW). I've kept using it with current production (bought in 2022) HD600 (300Ohm, 97dB/V according to official specs), and also threw plenty of others at it like HD414X (2000Ohm, 94dB/mW), including less demanding headphones like SHP9500, HD598, Koss Porta Pro, Creative Aurvana Live, Samson SR850, and earphones like KZ ZVX, FAAEAL Snow-Lotus, BGVP DX6. At one time I also had Topping L30 II, but I've returned it, cause I didn't felt it was worth the money vs U3. For reason unknown to me L30 II seemed to improve soundstage accuracy in fps gaming, but in music I didn't felt I needed to spend $150 on it. If I was pressed hard maybe the treble on L30 II were a bit smoother, but also more prone to sibilance at the same time if that makes any sense. I was concerned if my unit of L30 II worked properly though, as it was constantly running hot/at full blast even without input signal present, the PSU was a bit warm when the amp was turned off, and I could not distort HD600 with power from it. My only qualm with U3 is a short sound when powered on/off, its kind of "shhh" as when you turned off an old black and white CRT ages ago, it is less audible on high impedance headphones, but I almost feel like a pressure effect (I felt a bit of it with L30 II as well).
This is my first post, so I'm sorry if I've missed some rules, feel free to point that or any annoyances with my post, out.
Product page specs
Douk Audio U3 Mini Class A Headphone Amplifier HiFi Desktop Stereo Amp
Warm tips: Not inlcude power adapter, recommend to use original high-quality power adapter above 5W. For example: the current should be above 1A if use DC 5V while need above 0.5A if use DC 12V power adapter. Features Adopting innovative circuit design, DC 5-20V wide input working voltage, the...
doukaudio.com
IMD
Power output
10Ohm - 420mW
33Ohm - 509mW
82Ohm - 396mW
240Ohm - 192mW
620Ohm - 84mW
