My current setup is: Wiim Pro streamer => SMSL SU-1 DAC => Marantz PM-68 => Sonus Faber Concertinos + REL Strata III subwoofer. The Marantz and Concertinos were bought in 2000, and the REL probably in 2003. Since moving to a new home last year, with a larger living room, thick walls and distance from neighbors, I've been playing louder than I used. The Marantz seems unable to handle this, it cuts out at higher volumes, especially when percussion is strong. I've had it serviced by Marantz. Nothing wrong with the amp, according to them.
So I'm looking at replacing the Marantz with a Douk Audio A5. This amp has an adjustable highpass filter and seems to have enough power to handle the Concertinos.
Can anyone think of any objections to this plan?
And do I understand this correctly? In order to utilize the Douk's highpass filter, I will need to go from the current high-level wiring (Neutrix plug into the sub, bare wires into the speaker terminals on the amp) to a low level connection (from the 3.5mm pre-out on the Douk to the RCA low-level input on the sub)?
