Hello all, I'm new to the DIY amp/speaker world, would like to try out building some of these kits, I am not an electrical engineer but I have soldered on a PCB. I'm just trying out new things whilst in retirement and thought maybe I'd give Purifi a go. I'm learning as quickly as I can, so if my questions annoy the more seasoned of you, well, what can I say, try to keep in mind that you were once where I am knowledge-wise. One nube question that I have is how does the 1et400a board "know" what impedance my speakers are (they are manufacture-rated at 6 ohms, 3 ohms minimum, and are 86dB sensitive)? Second question, how does the board "know" what voltage it's being supplied (230 vs 120)? Or is this independent of the Purifi board and related only to the power supply board? Third, if I buy the Eval-1 kit from Purifi and pair that with a Hypex SMPS1200A400 2x64 VDC 1200 watt switch mode power supply, making sure all connections are correct, that's all I need to do to try out the Purifi "sound" (outside of installing everything in a box), yes? (If so, it almost seems radically too simple for an uninitiated person like me.) Forth, do I need to take into consideration the particular output specs of a preamp (or if no preamp a DAC) in order to fully test (sonically) this kit?
