Hello, we tried to detect this behavior
Yes, if no source is connected AND the RCA input selected, we can hear a noise on the right channel.
This is because the switch connect negative input with ground, and cancel the balanced design that remove any perturbation.
We found that this perturbation comes from SMPS1200 main capacitors.
One easy solution can be to route the right input wire under the IEC connector, along the back panel.
But this problem only occur when there is no source, because wires are on air and act as antenna with 47k impedance.
When a source is connected, no sound can be heard.
However, from today, we will take this parameter into account for our next assemblies.
