So I've finally got round to re-doing the dirac measurements and filtering after converting my small study into a mini cinema.
The room is about 2.8 by 3.5 meters (definately non ideal. Two side walls are glass (yes, it gets worse). Left hand wall has curtains. Right hand wall is a door into the living room, so does not. Floor is carpted - a mini sofa is in the listening postition, with shelving behind it offering some diffusion I guess. There is also a small window on the back wall with blind over it. Front wall has a large TV with the main speakers (DALI oberon 5) on either side. A single 12 inch sub (BKElec XXLS400-DF) completes the arrangement on the left hand side, in front of the left speaker. With the room/tv and sofa sizes there is no real scope for position adjustment of anything in this small room.
Amp is an aging Sony AVR, and I've used the AVR auto cal to integrate the Sub (Digital Cinema Auto Calibration??)
I've then run Mini DSP Flex Dirac on top of that treating the speakers/sub as an integrated speaker set.
In the following 4 screenshots, I show the DIRAC filter design page, then meausurements from REW of:
1 - Dirac OFF and AVR set to analoge direct (no processing)
2 - Dirac Off but AVR processing on (the result of auto cal)
3 - Dirac and Auto cal both enabled.
1/12 smoothing is applied.
To be honest the sound is significantly improved with DIRAC on - even compared to the auto cal. But the plots are significantly less smooth than others I've seen - and there is that big dip at 70Hz or so
Are there any obvious improvements I could get? Thanks for looking.
