wheelbarrow
- Joined
- Mar 14, 2022
- Messages
- 5
- Likes
- 4
Hey ASR forum - first post after hours of reading through Dirac stuff on here! After lots of searching, I still have some questions. I currently have a 3.1 setup with an Onkyo RZ50, as well as an office 2.1 setup with a NAD D3045+Mac Mini (intel).
My questions are:
Question 1:
If I want easy, simple Dirac measurement and setup, including setting a single subwoofer crossover automatically (meaning I leave the crossover knob on the sub as high as it will go or disabled and set sub volume knob to -10db or -15db), that means I require the newer Dirac Bass Management upgrade. I have no interest in multiple subs at this time, but do recognize the multiple benefits of Dirac Bass Control for single subs.
Is it possible to purchase this upgrade on the laptop and then use it on the RZ50, since it has the independent or LFE sub channel? Or does the RZ50 require some type of firmware or hardware update to support that? Unless it has to do with how the RZ50 implements a subwoofer channel in hardware, it doesn't seem to me like it couldn't be added via a software patch, right? For any Dirac employees here - I would gladly pay for this.
Question 2:
For the office 2.1 setup using the D3045 - I assume I cannot get the FULL benefit of Dirac Bass Management/Control without actually using an AVR that has a discrete sub channel (or running a complex multichannel dac/pre/power amp setup). I do not want that - I want easy. Set it and forget it. Am I right on this?
Question 3:
I have seen some discussion on using minidsp products in the chain for a 2.1 setup to add subwoofer correction, but don't have clarity on if they will actually allow full utilization of Dirac Bass Control. What exactly do I gain by adding a minidsp to my D-3045 setup?
I assume it just creates a third channel by taking low frequencies from the L+R, and then dirac can mess with that channel discretely. But minidsp stuff doesn't support Dirac Bass Control - so it seems not worth it for a ton of hassle.
Question 4:
Also for the office 2.1 setup w/D3045 - assuming I do not switch to an AVR/complex preamp setup w/Dirac Bass Control, is my only option here manually setting sub crossover after eyeballing the stereo license dirac curve measurements/listening to sub sweep tracks? I know learning to measure and adjust with REW is probably best, but I have zero interest in committing the time to do that. Again - easy button is what I'm after here.
Question 5:
For the Dirac license types - is the ONLY stuff you gain by upgrading from stereo to multichannel the ability to add Bass Control upgrade (along with all the multichannel options)? Or are there other features you get with the multichannel license beyond just more channels + option for Dirac bass control?
Thank you!
My questions are:
Question 1:
Question 2:
Question 3:
Question 4:
Question 5:
Thank you!
