Denafrips Ares II + Topping Pre90 impedance issue
Impedances should be fine.
Don’t know about that driver, but if you are saying it attenuates DSD then it must also do so by some digital-to-digital conversion.
No idea to be honest, but as far as I understood it should be using the windows mixer, which for ne means it converts dsd to pcm. Was actually looking for someone to confirm.
So I can now confirm that in terms of impedance matching they're is no issue going Ares II - > Saga S - > xduoo-ta-26 - > Audiolab 8300A. There is no loss of bass. There is however a boost in treble, which changes the sound enough to make me take out the schiit from the signal path and use roon dsp instead, converting dsd to pcm be damned.
Folks, I'm also not happy with the sound of the Pre90 - veiled in my system. The dac is schiit yggdrasil which has an output impedance of 75 ohms. Is this the culprit? (Also, the dac has two sets of rca's and a set of balanced cables hanging of it; would this make any difference?) Thanks in advance!
