How many dimensions is it? Show your work.If the output levels from a DAC differs then the gain needed by the amplifier to drive speakers changes, so its not a one dimensional issue.
Well its at least 2 dimensional, the DAC output and the amplifier gain are both variables.How many dimensions is it? Show your work.
The DAC's operation denotes that when converting all those zeros and ones to analogue that the DAC will output will be the same as another decent DAC. The buffers/OP amps that are after the DAC IC will be transparent to your ears as OP amps are very good now. There's nothing more in the signal path because after the buffers it's the output terminals at the DAC. The output voltages will vary from unit to unit and we know you know how to level match or we think you do. Level matching can be done properly when using a oscilloscope or a AC volts meter and both metering methods will use a sine wave to ensure the voltage is consistent across all tests and not varying like a musical waveform does.Well its at least 2 dimensional, the DAC output and the amplifier gain are both variables.
You just made a change so you are now actively listening for differences and listening more attentively. So you notice things that were in fact there all along.versus the khadas it seems to sound like a discernable step up
i like the 12v trigger and remote and bluetooth such that it is probably okay even if it doesn't produce better analogue - but i am an attentive listener even before the change, and there are frequencies coming forward that i hadn't been aware of previously, and the bass response seems to somehow make the notes very distinct
might be the filters (that i can't find in the menu) - or am i deluded by investment and expectation?
There's several clues.it sounds "different", just like the internal dac in the nad d3020 sounded distinctly different to the khadas feeding analogue into the same amplifier - most obvious on a few songs that are my "go to" standards for auditioning equipment -
Peeking and level-matching. Basic controls are basic.humour me and spell it out please
You don't need "sophisticated equipment" to perform some basic controlled listening. I think Amir has some videos on this.so without sophisticated equipment to measure these, i will have to be ignorant i expect
but i am happy it sounds better, so there's that
Unless something is broken, then it won’t be “decent”.Should?
No.as i am quizzing elsewhere, would a better power supply for the dac used bias the quality, as i understand that transient peaks may be compromised if there isn't enough "reserve"
does that even apply to dacs?
but presumably a more quality power supply can influence performance ?
Yes, I have experienced sound differences between DACs having multiple amps and dacs in my collection. From the forums one can infer that amp's input impedance and DAC output impedance do affect the sound between DACs and it is quite important to have them meet the 1:8 ratio or higher or in other words the amp and DAC pairing need to "match".thanks raif71, for suggesting there may be some plausible possibility for hearing a difference
if i am no closer to an explanation (apart from bias), does the presence of the famous ess hump in the khadas readings, and its absence in the e70 readings make diddlysquat difference to what i might hear ?
i appreciate the experienced responses of the forum members as i have no formal training in the electronics involved, but i am listening
Of course a terrible power supply will affect sound as will effect the way a component works. Can a 'better' power supply improve sound? Have a listen.
If the regulation and basic filtering in the power supply and dac supply input is crude enough, then slapping in a humongous supply may make a difference, but in modern well isolated dacs which are tested and proven to be basically immune from the supply these days, it should make no difference at all as long as you don't know which supply is used.Of course a terrible power supply will affect sound as will effect the way a component works. Can a 'better' power supply improve sound? Have a listen.
