maximit
- Joined
- Mar 4, 2022
- Messages
- 97
- Likes
- 117
Dont know if Im the only one but when I got the Aeons I loved the look of leather but found the strap to be very thin, stiff and not comfortable. I kept playing with the sliders non-stop trying to get a perfect fit and the cups would turn in weird angles because of it. I thought it would soften up with time, but it did not so I designed a replacement strap made out of polyurethane that is not only wider but also stretchy. Similar to how the high end Dan Clark models like Stealth and Expanse stretch to fit, this has some stretch to micro adjust instead of using the sliders, they are now tightened down to not slide around. I wanted to see if I am the only one with this issue or if others have had a similar problem with the leather strap.
