Dan Clark NOIRE X Headphone Review
Rate this headphone:
    Votes: 5 1.7%
    Votes: 12 4.0%
    Votes: 84 27.9%
    Votes: 200 66.4%
This is a review, listening tests, detailed measurements and optional EQ of Dan Clark Audio (DCA) NOIRE X closed back headphone. It was sent to me by the company and costs US $999.99.
This is one high quality and gorgeous headphone. It is more compact and lighter than my daily driver, the DCA E3 which I appreciate. It comes with a very flexible and nice (silicone?) cable with just the right length for desktop use.
As with the last few reference quality headphones from DCA, the NOIRE X uses "meta material" to tune the response of the headphone. Development process included evaluation with both GRAS 45CA (same fixture I have) and B&K 5128 (one that I evaluated). Some of the tuning is informed because of this dual testing. I will comment on this in the measurement section.
I received the headphone about a week ago and have been listening to it and only measured it tonight. I found the headphones very comfortable to wear for many hours on end. The automatic fitment works well. I believe work has been done to make sure the headphone is more resilient to how one wears the headphone.
DCA NOIRE X Measurements
As usual, we start with our headphone frequency response measurements. Fitment on the fixture was easily achieved:
DCA NOIRE X Closed Back Harman Headphone Frequency Response 5128 GRAS 45CA Measurement.png
On my 45CA fixture, high level compliance is good but we have localized areas of deviations. As some of you know, there is no official target response for 5128 fixture. DCA has adopted its own (based on Oratory DF?) and using that, they don't see the two deviations I have marked. They performed sweep listening tests and feel that the 5128 response is closer to what they hear. I will address this when I EQ the headphone in the listening test section.
Here is the differential relative to our target:
DCA NOIRE X Closed Back Harman Headphone relative target Frequency Response 5128 GRAS 45CA Mea...png
Other than the peak at 4.7 kHz to the tune of 3.7 dB, the rest are quite minor and would easily fall in the "error bars" of the research for target curve.
There is more distortion than previous reference level headphones from DCA:
DCA NOIRE X Closed Back Harman Headphone relative THD Distortion Measurement.png
As noted though, at 94 dBSPL, distortion remains quite low in the rest of the spectrum. Specifically, it hugs on "0%" line quite closely from 2 to 5 kHz where our hearing is most sensitive.
Of note, DCA found that the GRAS 45CA measurements show less distortion than that of 5128, indicating the microphones in the fixture itself has lower distortion.
We see a couple of reflections causing non-minimum-phase response in Group Delay but otherwise, we have the typical clean response from DCA:
Impedance is very low at just 13 Ohms:
It is flat though as you see so source impedance won't change frequency response.
It is more sensitive than other DCA reference headphones which is nice:
Quickly switching from E3 to NOIRE X resulted in noticeably higher volume. This will open up a lot more headphone amplifiers that can drive the NOIRE X.
NOIRE X Headphone Listening Tests
As I noted in the introduction, due to being overwhelmed with work, I just listened to the NOIRE X and did not measure it. Immediate impression going from E3 to it was total familiarity with perhaps, the high frequencies standing out just a bit. Post this measurement, I brought out the EQ to examine the audible effect of deviations I see in the frequency response:
I had to dial down the bass filter at 111 Hz as the predicated deviation while nice on some tracks, took the impact away from bass heavy tracks. With the reduced amount, you have a tighter bass response while still having 80% of the impact. The sum total of the rest of the filters gave me the impression of more separation of instruments though the effect is very subtle.
Above was sighted. In ad-hoc blind testing, I guessed correctly only 1 out of 3 as to which was stock and which was the EQ! So the effect is quite small and subtle. In that sense, I don't think I can make a strong case that these deviations are real. At the same time, I can't say they are not either. To wit, I am listening with the EQ on.
Listening to music is a delight with performance that is both familiar and superbly high fidelity.
When DAN Clark brought the "meta material" innovation to headphones with the Stealth, the improved performance was real but so was the $4,000 price tag. We all wished for lower cost headphone which they delivered with E3. But at $2K, still quite expensive. Now we have an under $1,000 headphone that delivers all that technology in a compact packaging. It has a bit more distortion but perhaps with a tuning that some like better. I know the comfort is there as I prefer to wear it for long hour listening sessions.
Subjective experience of NOIRE X is stellar: every reference track I played put a smile on my face. It feels like I am wearing super high quality, full range studio monitors strapped to each ear! Objective data backs that, pleasing both sides of my brain!!
It is my pleasure to recommend the DCA NOIRE X.
Thanks for the nice review, Amir!
A couple of things to note about the headphone:
1) There are new ear pads, with an Alcantara suede finish on the contact surface for improved comfort
2) NOIRE X includes our self-tensioning headband
3) Ear pads are enhanced to reduce potential for foam rolling, to extend usable pad life and enhance comfort
4) Numerous driver updates to improve consistency and performance
I thought it'd also be interesting to post some results from the 5128, with the diffuse-field and Harman EQ points used as a "Harman-style" reference. I will publish a larger post with analysis and commentary comparing the GRAS and 5128 later. The target curve in the 5128 measurement was derived by applying Harman Curve EQ points to the B&K diffuse field compensation curve. It is interesting to note just how close the NOIRE X fits this curve, and also where there are some real differences relative to the GRAS in measured results. There are interesting implications for this in setting EQ, which I'll discuss in the technical post.
For a different view on THD I thought people might enjoy this, measured 85dB @1KHz on the GRAS. Note at 4KHz THD goes as low as 0.006%!
Lastly, here's a beauty shot for those who like these...
Wonderful, looking forward to an open back version to complement my E3. Need an open back version now that I need to be aware when my kids wake up in the middle of the night during my music time ☺️
Each headphone interacts uniquely with the acoustic impedance of the ear canal, a phenomenon known as the headphone transfer function. This interaction causes each headphone to produce different peaks and dips above 2000 Hz, depending on the measurement rig used. Since different measurement rigs have varying acoustic impedances, a peak observed at 4000 Hz on one rig, such as the 45CA, may not occur at the same frequency for every individual or may not occur at all.
This doesn't mean the 4000 Hz peak will be inaudible for everyone else, but it also doesn’t guarantee it will sound identical to how it appears on the 45CA.
The real question is: which measurement rig most closely matches the average acoustic impedance of the human ear? 45CA has a prerefence curve that helps us to evaluate headphones with each other better, that's very convenient. However, there is no strong consensus among engineers that 45CA is the closest to the average human ear canal.
Headphone transfer function is something that Sean Olive has been investigating since 2022 and the results are interesting.
Here’s how four different headphones measured across various individuals:
Sean Olive's full presentation: https://danishsoundcluster.dk/wp-content/uploads/2022/11/Olive_DSD_2022.pdf
How does something like the AKG 371 compare...is it 90% of the performance for 15% of the price?...does a bit of EQ make it 99% of the performance...$1000 for a pair of headphones seems ridiculous....
How the soundstage compares to the E3’s? E3 to me felt intentionally limited to a cone of sound in front of the forehead
You have seen the pricing of headphones for the last probably decade right? $1000 these days is far from the top pricing tier, and frankly, if the build and sound quality are there, people can make the case for $1000 being okay.
I have the AKG371, they sound great but absolutely no soundstage , after 30 min my ears are so hot and start to sweat, I have to rest, also many reports of durability issues, and the looks is meh
But there is a headphone or IEM specific one as Sean Olive has developed recently. Like doing a series of measurements by multiple persons and positions on both rigs with a single headphone and then take the average difference as a "transformation function". Also the average of different heaphones will probably not vary too much from each other (to be confirmed|)
I spoke with Sean about the 5128 curve I referenced, he was part of the "peer review" group I put together to check my 45CA vs 5128 measurements. More to follow on this!
Thanks for the review amirm.
I just can't see the point in spending £1000.00 on any set of headphones these days when a £25.00 set of ear buds can give much better conformance to the ASR popular house curve, if that's what one is after.
I might change my mind if I could hear the DC headphones for a while, but with equalization some of the much cheaper headphones are likely to perform close enough to the DC offering under discussion at a fraction of the price.
What about driving it with rme adi2?
