- Joined
- Jun 19, 2018
- Messages
- 6,652
- Likes
- 9,406
My father in law had a BOSE sound wave cd player for over 10 years and loved it.
It developed a fault and, with it being out of warranty, decided to take it apart to see if he could fix it (he's like that).
Anyway, he was shocked at what he saw inside.
Basically a small PCB with speaker wire going to the two tiny 2.5 inch drivers with an elaborate series of slats which directed the soundwaves (for want of a better word) which gave the illusion of good sound.
I guess it looked something like this?
I don’t have any published tech info on this design, but what that looks like to me is a long port or transmission line. In other words, it is the kind of thing you see on most standmount speakers, folded upon itself to maximise space inside the small enclosure. This is no more a “trick” than in any other design in which it’s used. It has the effect of allowing the small drivers to produce more bass than they would in a sealed enclosure of the same volume, with less cone excursion (assuming they are high-pass filtered at a suitable frequency to prevent over excursion, which no doubt they are). It makes sense in an enclosure of such a small volume.
Now, I’m certainly not saying this justifies the many 100s of $$$ the unit no doubt costs My personal experience of Bose products is that they tend not to perform as well as some similar units in their respective price ranges. But I wouldn’t call this a “trick”; it’s just a smart way to get a small speaker to produce an adequate amount of bass.
