Yeah I know. It was a pretty unscience thing to say to just trust somebody.
But I am afraid that if I buy the RME DAC that I would not do the blind test in a good way. I don't have something where I can switch quickly between the dacs and I don't have someone that is pretty technical to help me to change things behind the curtain (so to speak) to switch the connection relatively quickly. And with that, you are rapidly going to go in a biased way when you know things.
The controls were to ensure the whole song was recorded and started at the exact same point (trimmed at the beginning).
The subjective control was to not look at the screen and having the player on 'random' (as far as it is random) and check to see if all files were used when skipping.
Only one very high quality and to me familiar song was used so rather limited test.
Then listening without looking and trying to find differences.
I could not say which one was which.
The Mojo measures pretty well and also the other DACs are no slouches.
If there are sonic differences they are inaudible to
me.
I can't hear the differences subjective reviewers claim there are anyway so either my brain can't create it and theirs can or am not trained enough or the differences are too small.
I did pass the 'golden ears test' and have some experience with sound reinforcement, studio recordings, knowing how instruments sound IRL, electronics, and evaluating sound.
The reason I don't believe my ADC changes the sound in an audible (but certainly measurable) way is that it was used at 192/24 while the playback was at 44.1/16 (where audible differences would be most obvious) so the ADC would have no trouble recording everything at the analog outputs.
Indeed, that's why I keep repeating it, one should seek out their OWN hearing thresholds. This isn't done overnight. I have over 30 years of 'experience' and testing every now and then so I know what I can here and having tested some other individuals have confirmed other people were not different than my experiences.
Do NOT trust my findings... the controls are good enough for me. Not DBT, not scientifically lab conditioned. An amateur playing around with what he likes.
When you were to end up with the DAC2 you really don't need to test or compare it. Measurements tell me it is far beyond transparent. Overkill for me so won't buy one myself but strongly recommend one (based on measurements)
When you can enjoy music with the stuff you have there is no need to upgrade unless you need the functionality it provides or 'want to be sure'.
Yes, some other DACs may surpass it on the Amir scale (SINAD) but do not have the options the DAC2 provides.
