DAC powersuplts D30/DX3Pro
aoaaron
Hey, can I mix power supplies? I.e. does the power supply from the Dx3Pro work with the D30? I'm wondering as i have a noisy PSU but didnt want to risk damaging my D30 dac.
andreasmaaan
AFAIK they both use 15V DC supplies, but you should check the power supplies/backs of the units to make sure both are rated the same voltage.
If one supply is higher current than the other, use the higher current one.
