So I'm looking for a good DAC/Amp combo for around $400 - $500
Must haves:
- low impedance single-end headphone out
- balanced line out for powered speakers (XLR)
- main volume control will control both headphones (when plugged in) or speakers
- good Windows 10 drivers that allow for problem free use and stability. Should also allow for seemless sample rate switching from file to file when using software such as foobar through WASAPI or ASIO.
Nice to have:
- display to see sample rate and stream type (pcm, dsd, etc.)
- digital volume control so there is always perfect channel balance
- small form factor
- additional balanced headphone output
I had looked at the Topping DX3 Pro, but it doesn't have a balanced line out which with powered speakers I believe can cause issues at higher volumes (such as a hum, etc). Also don't know if the main volume control on that will affect the line-out (so that it would function as volume control for my speakers). Otherwise the DX3 ticks all the boxes.
Any suggestions? Thanks!
Must haves:
Nice to have:
- small form factor
