Pieter1267
- Joined
- Nov 20, 2024
- Messages
- 181
- Likes
- 100
Hi,
So I have 2 Neat Acoustic sx2, down firing port floor standing main speakers. I also have an SVS sb 1000 pro sub.
The main speakers now go through the minidsp in a crossover. I decided to plug the downfiring ports.
The svs manual says I should set the slope at 12 for sealed main speakers, and 24 for ported. Now that I closed the ports I changed the slope in the SVS app from 24 to 12db slope. Wich sounds a lot cleaner. However I noticed the Minidsp crossover are all set at 24. I know keeping all of them in the same slope setting is best.
My question: since I plugged the main speaker ports, is it better to set everything at 12db slope? Or is 24db better? 3rd option: can I just keep the svs app setting at 12 and also maintain the 24db setting through all outputs in the minidsp? Kindly your advice. Thanks in advance!
