sigbergaudio said:
My experience is that many of the really impactful sounds (like percussion) are quite wideband, so you need both the low-end and the range all the way up to 500hz in order.
I also swear to sealed subs, but recently ended up designing our full range loudspeaker to be ported to get enough capacity in the bottom end. And tuned to 28hz I'm hard pressed to say that it sounds any less tight and punchy than the sealed subs if I'm honest (which I try to be).
I agree 100%.
Now my sighted, flawed, changing tuning of my double 15's (just block 1 of the 2 ports), made an audible difference changing the tuning from 40hz to 27hz. The sound went from a thunk thunk to boom boom.
People talk of sealed bass being faster............
I stuffed both ports, there just was an octave less of bass, not faster, just not there....................
I think tuned speaker has the same group delay (as a sealed) 1 octave above tuning, so a 30hz tuning is just as fast as a sealed near 60hz (kick drum ?), but with more output below 60hz and much cleaner due to the cone not moving as far, then less and less till at tuning.................
A friend with 3 x 10" believed that sealed was "faster". He was amazed when a double 12" push pull PORTED to 27hz was "faster" and cleaner....................
Perlisten is using push pull now just as m&k did (early 90's ?) then Kreisel Sound (2012 review)............................
So, there must be something to the design, no ?
Massive amounts of output is not the only mark of a flagship subwoofer. Though we can compete with the worlds best in that category, our design metric is to have ultra low distortion to create the subtlety of every detail of the bass guitar, to the 12Hz stomp of that T-Rex.
www.perlistenaudio.com
Ken Kreisel’s new DXD-12012 / MX-5000 Mk3 subwoofers.
www.kreiselsound.com
Ken Kreisel of M&K sold his company years ago, and it continues to thrive. Now he is back, selling subwoofers and speakers mainly to the pro market, under the company name KEN KREISEL.
hometheaterhifi.com
I've made 3 push pull slot loaded subwoofers. First was proof of concept double 12's, then 2 boxes of double 18's, then a single box with 4 x 12's.......
here is a link to some push pull diy stuff..............
This is a new thread as suggested by Moray James. For Moray James: What I did was to simulate the enclosure with two speakers in Horn Response. I simulated it as you would an Altec A7 type of speaker but with a front chamber on the horn. This front chamber would be the plenum if I am doing it...
www.diyaudio.com
Transients, or speed usually can be an integration issue.
I believe an audible culprit is the phase wrap (cause time delay) depending on the crossover point/slope..............
I just cringe at adding 20db of boost to make the amplified subwoofer get flat down to say 20hz in its too small of a box.
