There are some really bizarre things going on with those MDAT's. But first let us answer your question.
First, are we dealing like with like? I imported both MDAT's into the same graph and time aligned + SPL aligned them. The measurement marked "SEALED" is in red, and "PORTED" is in green. The answer is "not really". Although the bass equalisation is roughly the same, there are substantial differences above 1kHz, most notably a huge dip at 2kHz in the PORTED measurement. This isn't going to be due to a difference in subwoofer layout, it's going to be due to different mic position + maybe something else, e.g. a large piece of furniture that was present in one measurement but absent in the other.
More bizarre are these huge spikes in the waterfall at 450Hz and 750Hz which remain flat and do not diminish in intensity - a measurement artefact for sure. Both peaks are squarely in the vocal range and as loud as the measurement itself, which makes me think that someone was yelling or a dog was barking when the measurement was taken. I would have rejected the measurement immediately and retaken it. This means that from now on,
all the "PORTED" measurements are suspect and must be interpreted with caution.
Group delay view. Again, SEALED is red, PORTED is green. You can see that above 10kHz the group delay is the same, meaning we can compare the GD below 200Hz.
I have drawn in dark blue the general trend for GD. You can see that the red and green measurements are almost the same. This does not necessarily mean that the GD of your sealed sub is the same as the ported sub, as I mentioned before there are too many confounding variables to draw that conclusion. All we can say at this point is that the difference in GD is not the reason why you prefer sealed over ported.
A couple of other things stand out. Look at the peaks marked 1, 2, and 3. These are non minimum-phase areas of the frequency response. These will be due to two or more sound waves interacting with each other - perhaps the direct sound with its reflection, or the direct sound from two speakers (L and R, or one of the speakers with a subwoofer, or two subwoofers, etc). The peaks marked 2 and 3 are absent in the SEALED measurement, and are likely NOT due to the measurement artefact discussed earlier since those are at 450Hz / 750Hz. It is likely due to subwoofer / mic positioning.
The double impulse on the green curve at the start of the step response tells me that this is a measurement of two main speakers together, with the microphone not well centred between the speakers. The direct sound from one speaker is arriving earlier than the other.
The tail of the step response is good for observing ringing behaviour in the subwoofer. This is the same measurement as above, but stretched out to show 450ms instead of the first 10ms. Here, you can see the ringing behaviour between "PORTED" and "SEALED" is very different, with the PORTED curve showing "ringing" that is louder than the main impulse itself. I say "ringing" because I am not sure if this is actual ringing or due to the measurement artefact we saw earlier. Certainly, if you have multiple subwoofers and they are not time aligned properly, you can observe "ringing" that looks like this.
And finally, the spectrograms. These have been normalised to the peak value at every frequency. The artefact shown earlier is well above this frequency range, so the spectro is interpretable. Here you can see that the decay of the sealed sub is superior to the ported.
