The LFE channel is normally limited to 120hz, altho can be higher but rarely is....at least that's my understanding.The LFE channel carries a very wide bandwidth.
True. Thinking about my comment again, it isn't the LFE channel that is the problem for most movies. The biggest problem is the redirected audio from all of your speakers.The LFE channel is normally limited to 120hz, altho can be higher but rarely is....at least that's my understanding.
That coiuld be different. I don't have particular issues with the redirected bass either otoh.True. Thinking about my comment again, it isn't the LFE channel that is the problem for most movies. The biggest problem is the redirected audio from all of your speakers.
Well, I'm at a bit of a loss with that analysis. See my latest reading. I tested the L and R sealed and the response dropped like a rock. Am I supposed to turn my subs down about 8db to hit the 60 crossover?But when you cross against a subwoofer you need to match the slopes. A sealed enclosure has 12 dB/octave which will be 24 dB/octave with the standard AVR filter of 12 dB/octave. This will be matched to the AVRsub slope of 24 dB/octave. The ported response of the Revel is rather complex as you can see from measurements, not easy to match.
So where should I be aiming the crossover? I'd have to drop it about 8 to 10db to get it crossed at 60, no? That doesn't seem right.It looks like when in sealed mode, the response starts falling from 150Hz thereabouts. The rolloff slope from 150Hz is less steep... which is consistent with sealed behavior.
What software are you using for this? Audacity?The frequency response plot for the track "Sixteens Tons" is shown below. It shows a large amount of bass energy in the 36–46 Hz region.
The frequency response plot for the track "Limit To Your Love" is shown below. This has some strong tonal information in the 18–30 Hz frequency range.
The frequency response plot for the heartbeat at the beginning of Pink Floyd's "Dark Side Of The Moon" album shows a strong, broad peak at 31 Hz. It's interesting to listen to it as it builds in intensity.
If the subwoofer's ability to reproduce very low frequency content in music is of particular interest, then the track "Bass I Love You" provides a lot of low-frequency content at 9 Hz and 18 Hz, as well as 31 Hz. That should help test out most subwoofers quite nicely. The frequency response plot is provided below.
Yes. MultiEQ-X. More I think about it. If I go down this path I would have to take all new measurements with the mains sealed wouldn't I?..What software are you using for this? Audacity?
Sorry I was on mobile. You were asking someone else this question.What software are you using for this? Audacity?
Correct. Higher crossovers need a steeper slope to avoid sound quality degradation. To add, there is some crossover into the discussion on localizability of bass:To add additional complications- I use digital crossover foo_subwoofer. I found out that crossover slope steepness has a subtle impact on sound (upper bass) quality where the subs-mains transition. So does mains-subwoofer delay settings therein.
Am I reading it right that perhaps crossing at 100 is the play?
Right. That's what I thought I was seeing as well. Thanks.Based on your measured mains FR amplitude response, these are my thoughts:
- if you're aiming to crossover in the 60-80Hz region, leave the mains as ported.
- if you're aiming to crossover in the >100Hz region, you can experiment with the sealed setup.
indeed, that was also my conclusion, something is very wrong with that...The lower output below 50 hz for the 80 and 100 crossovers makes no sense to me. Why would that happen? Unless most of the lower frequency energy is being supplied by the mains and not the subs.
View attachment 347475I’m not facile with this sort of thing, so please excuse my crude attempt, but what I’ve included here is a screen shot from the Rythmik L12 site. It shows that the FR bandwidth is different when using the Line In input vs. using the LFE input.
So, the reason Amir’s graph shows the sub’s response rolling off above 90Hz is not because of some technical limitation of the servo design, but rather because of an optional design feature intended for a specific use case.
A MultiEQ-X room adjustment? I have no idea, I took all of those readings back to back.The lower output below 50 hz for the 80 and 100 crossovers makes no sense to me. Why would that happen? Unless most of the lower frequency energy is being supplied by the mains and not the subs.
Sorry about delay. I'm really sick.You have M126Be's. How do you cross them?
Howdy, I don't agree.But when you cross against a subwoofer you need to match the slopes. A sealed enclosure has 12 dB/octave which will be 24 dB/octave with the standard AVR filter of 12 dB/octave. This will be matched to the AVRsub slope of 24 dB/octave. The ported response of the Revel is rather complex as you can see from measurements, not easy to match.
I treat integration and room effects separately. Having sealed speakers or speakers where ports can be plugged getting that ≈12 dB/octave slope and crossing at 80-100 Hz with the standard 12/24 filter is the start. Using a separate DSP is another solution for integration. Then use parametric EQ to dampen room modes.Sorry about delay. I'm really sick.
About 90hrz.
60hrz is to low for really high output levels in my space but it would be fine for most times.
Still I'd much rather have the subs handling the bulk of the 50-90hrz range vs a pair of 6.5s.
They are much more suited to delivering those frequencies.
I've used with a few different subs.
8's 10's 15's of various design.
Bear in mind I am mainly a 2 channel listener so this is a music system. No movie, LFE, rather miniDSP and ability to very easily make adjustments and blend subs and mains.
Fwiiw I don't think there is any benefit to sealing the M126be. Unless there is midrange leaking from the port. (Which I've never heard is an issue with this model) The drivers are not meant to be sealed in a box that 'big'(it would be about 1/3 that size if designed as such) you are likely losing powerhandling & output & gaining nothing back.
Changing the crossover is not the only variable. Each time you adjust you may have to tweak in relationship to other variables. Also there are room modes, SBIR, Subwoofer(s) location, location of mains to walls ECT.
I also use a different target for the bass region room responce vs the flat slope you posted.
I also apply PEQ/room adjustments above about 150hrz to each L & R channel independently. Below that I generally apply globally.
I don't find this is the same as matching something like a tweeter and midrange.
Blending the sub is not delicate, it is almost a bit of brute force crude endevor.
The wavelengths are enormous and nearly 100% omni(unless crossing high to say make a diy 3way) and blend together very easily. They do not need to matched like the ideal on paper especially as they absolutely to do behave that way in rooms.
Then the many, many different room effects are massive and much room correction is used below 150hrz relative to other regions.
I've never had a problem getting superb blending with a little time involved to try a few different things. Though with miniDSP that is easier vs most AVRs still I could certainly get a good blend in the bass and especially if any PEQ or RC is going to be used.
Just measure with every adjustment and take some time.
