- Thread Starter
- #121
Trust there is no CE testing, certification or even marking on these units.
It is not easy to make connections to these batteries so likely that is what he is doing.
But at least he could upgrade from his plumber's soldering iron.../snarkI assume John sits hand soldering the SMD parts to them.
I'm heavily invested in the LakeWest MDAC2 project which is promising a new DAC later this year which will set me back around £1.5K plus DeTox and Dev Fees.
This I suppose. Yet another USB decrapifier.. thing
Thanks for posting - I just hope it's not your fire hazard in these pictures... the good news is that my own soldering skills seem plenty good for going into the audio business!Here you go. Older model. View attachment 37604
http://mdac2.lakewestaudio.com/USB_Detox.htm
I like the 'please note NON REFUNDABLE' lol
Just to add. Doing 'double blind' listening tests in HiFi is very difficult (almost impossible) particularly at home. Also I believe (just a guess) that it takes a fair bit of time to adjust to the sonic signature of a product and unless the difference is glaring obvious it may take weeks.
This is almost certainly not true.Also I believe (just a guess) that it takes a fair bit of time to adjust to the sonic signature of a product and unless the difference is glaring obvious it may take weeks.
LOL, that's a good one! .Is that that thing RoHS compliant?
I believed this for years but having settled on a system I was content with quite a few years ago I listened without any changes but nonetheless still felt the system sounded particularly good some days. Had I been changing kit I would almost certainly ascribed this feeling to a new component, but there weren't any.
Audio memory is very short and a bit louder always sounds more dynamic, so the only way to compare items, IME, is carefully level matched to 0.1dB and with instant switch over whilst listening to the same piece of music with the switch over done by somebody else without you knowing.
It is actually trivial to do with DACs using 2 line inputs on a preamp and two digital outputs from a CD transport to the DACs as long as at least one of the DACs can have its output level matched to the other. That is how I did it, with my daughter switching.
All the differences I was sure were there disappeared...
