Can you recommend speakers?
kulak
Hello friends, I am looking for an active speaker that can have an output of 100 dB or more.
1)Behringer PK112A 12 inch 600W Active Monitor Type Speaker
2)Behringer PK110A 10 inch 350W Active Monitor Type Speaker
Could one of the speakers I gave above be sufficient or is there a speaker you would recommend?
I will connect the speaker to the sound card (behringer umc1820)​
voodooless
Netherlands
What's the use case? What is the budget?
voodooless
Netherlands
kulak
kulak
I don't have a lot of budget, I live in Turkey and I'm looking for a speaker I can find here. Can the speaker I wrote to you meet the requirements?
HarmonicTHD
ppataki
Budapest
Those Behringers won't go above 100dB
Visit the Thomann website and check out the active PA speakers
The cheapest that claim to go above 100dB are the Fun Generation PL series
voodooless
Netherlands
We still don’t know what it’s for. As nearfield monitors these things will probably do 100 dB, but it would still be a very bad fit.
@kulak, help us out here, give us some more information!
kulak
kulak
130 dB'in üzerine çıkabilen bir amplifikatör önerebilir misiniz?
Translated by moderator. Please post in English.
Can you recommend an amplifier that can go above 130 dB?
voodooless
Netherlands
That’s a nonsense question. Amplifiers don’t make sound. How loud you can play will depend on the speaker connected to it.
Why now 130dB? Earlier you wanted 100 dB speakers…
If your not actually able to tell us any useful information on what your actually trying to do, this will be much last post here.
kulak
kulak
My question is shaped according to your answers.
voodooless
Netherlands
No it's not, you haven't answered a single question asked of you in this topic.
MaxwellsEq
MaxwellsEq
trigovina
Hi bro, My setup is; Focal Alpha Evo 65 + CXNv2 and i can say that i am very happy with my setup. I can hear all the details and the sound is so flat. I use deezer and my tv box is connected to the cxnv2 with toslink cable.
By the way whats is your budget in Turkey? I have purchased my Focals from Sescibaba in TURKEY.
My previous set up was; Wiim pro + Gustard dac and the same focals.
Depends on your budget and music source, i can tell you what you want.
jcris
Lakeport , Ca.
He kulak,
My 2 cents, what size room are you going to use this in? Perhaps a pair of bookshelf speakers with plate amps and dsp. There are many affordable options out there. Set a budget and make a choice
ZolaIII
From home and better pasive speakers you can buy right now that will top 100 dB SPL @1 m without compression for some normal price take a look at Wharfedale Linton's which are about 1100 € with stands (new but try to find them second hand for less). Even for them 100 dB is uper limit to pass reference white noise (-20 dB) calibration point at 4~5 m. For the amp take a look at Dynacord L1300FD and as it's with DSP (including PEQ) that will be sufficient enough (about 250W @ 8 Ohms with SINAD of 80 dB and low impedance tolerance to 2 Ohms loads).
kulak
kulak
Thank you very much friends, the problem was solved with your suggestions.
voodooless
Netherlands
So, what did you end up with? And we still have no idea what you are going to use these speakers for, so basically it's not possible to qualify any of the suggestions...
