Can we trust our ears?
Sukie
Referring to ears instead of hearing is not a good way to start.
I agree. Our ears are part of the chain, but that's it! Imagine relying on your ears rather than your ears and your brain. What good are a pair of detached ears?
I know what is meant by the phrase "trust our ears", but it suggests that the process of hearing is detached from the complexity of what is going on in the brain.
Apologies for the mini-rant.
andreasmaaan
"Can we trust our ears?"
It's sort of like referring to the front part of a microphone, and microphones are much simpler than hearing.
I thought it was pretty obviously a metonym (a synecdoche, to be precise) :p
Sukie
I disagree.
When it is used it often done so in a way that seeks to isolate the listening experience from what's going on in the brain. "I trust my ears" is often used to suggest that when differences are heard between differing audio set ups, they must be attributable to the audio equipment rather than to other factors, e.g. cognitive bias.
I would suggest that there is a substantial and demonstrable difference between the way in which people often use the phrase "I trust my ears" and the reality of the process of hearing, particularly when it comes to the other factors at play in the interpretation of the overall experience of that which we hear.
A synecdoche is a figure of speech with a far greater identify between the phrase that is used and the concept that is expressed.
In addition to this, synecdoche's change and evolve precisely because people challenge the identity between phrase and concept. That is why some slip from common usage and others replace them.
andreasmaaan
I think the OP made it fairly clear they sought to isolate the listening experience not from what is going on in the brain (which would be patently impossible) but rather from what is going on in the mind.
Anyway, there are no objective winners in debates about interpreting language - perhaps we shouldn't bother? :)
Kal Rubinson
Industry Insider
NYC
The reconstruction of the cathedral or hall sound field is physically impossible in home or studio conditions.
Full reconstruction is impossible, I will give you that. OTOH, one can achieve a closer approximation with the right tools and media. If you cannot grant that, you need to investigate more.
Kal Rubinson
Industry Insider
NYC
I fail to see how the subject in a subjective experience can distinguish among any of these paradigms.
Sukie
Surely the mind and the brain are integrally related. If you cannot isolate the listening experience from what is going on in the brain then you cannot isolate the listening experience from what is going on in the mind. That's the whole point of what I'm saying.
andreasmaaan
Ok, I worded my previous post poorly. The OP's use of "ears" was a stand in for everything involved in hearing other than confounding psychological variables. I think that was quite obvious.
Sukie
I agree and I'm not disagreeing re: OP's wording/meaning. Over 17 pages contexts and meanings develop that takes any thread into new territory and I suppose that's all I was meaning in my initial post. I am aware that I can become a little bit excitable when I see the word "ears" and immediately want to throw in the word "brain":)
andreasmaaan
Fair enough. I can definitely understand the desire to be precise when discussing these topics - something which I admit I wasn't a couple of posts ago :)
andreasmaaan
Neurologically, it is hard to find the border between these.
I'd be interested to hear you elaborate, if you'd care to?
The border I had in mind was not neurological but epistemic: by shielding the subject from knowledge of certain test conditions (e.g. which stimulus they are hearing), confounding variables are removed (which is not to suggest that it's possible to remove, or even be aware of, all confounding variables).
Kal Rubinson
Industry Insider
NYC
Ah. Under fully blinded conditions, one might expect so. The removal of all confounding variables is complicated by the fact that the test operators are as equally unaware of their unconscious psychological bias as are the subjects.
Katji
...The removal of all confounding variables is complicated by the fact that the test operators are as equally unaware of their unconscious psychological bias as are the subjects.
I suppose that is more a concern in some fields than in others, awareness of it, even studies on it, developed over time. (In the history of modern science. It was certainly known and considered in some ancient science contexts.)
Cortes
ok, at stereophile you need to refer to real science of mind-matter iterations to throw away all the AP measurements and come back without remorse to the happy subjectivist life
Kal Rubinson
Industry Insider
NYC
Where are you coming from? I was a career scientist until my retirement and I never disregard objective measurements. My comments here support the fallibility of subjective assessments.
tuga
Oxford, England
If the ear is not to be trusted, can we trust audibility research?
Thomas Lund
Industry Insider
Aarhus, Denmark
While human auditory diversity, physiological and mental, was described already by von Helmholtz (c. 1856), new non-invasive research techniques produce an overwhelming amount of data, some of which points to areas for improvement in lossy "perceptual" coders, hearing aids, audio formats, reproduction methods etc. Naturally, such findings can also be used to take a fresh look at the perpetual audio "inception dilemma", a room in a room.
andreasmaaan
Do you have any links you could share to some of the studies you're referring to here?
