Genelec posted an article on their blog with some nice pictures on applying research on"slow listening" to pro-audio monitoring.
Written by marketing people?
Written by Thomas Lund, Genelec’s Senior TechnologistWritten by marketing people?
You had it right the first time. Slow listening makes no sense.Written by marketing people?
I just saw something that proved what we hear is influenced by what we see. At least when it comes to speech. A person was making the lip motion for a "B" vs an "F", but the sound played was exactly the same. What you heard depended on the lip motion.
Active sensing ...movement is essential in hearing, cross-modal influence should not be under-estimated...
This reminded me of two humorous (but serious) comments about driver alignment on a loudspeaker baffle--first from the late Drew Daniels, JBL applications engineer, regarding his 'home made' large footprint low distortion loudspeaker
A review generally doesn't include new research. This one discusses theories (e.g. active sensing, perceptual bandwidth, latency of sensation etc.) in the light of a number of new in-vivo studies, and relate them to pro audio. The few "odd" references are there as examples of precisely that, along with 100 relevant ones.
The misrepresentation here of perceptual bandwidth - that seeing has the highest by far - confuses physiological and perceptual bandwidth. Other main take-aways from the review should be: Active sensing, efferent pathways to the ears are as important as afferent ones, movement is essential in hearing, cross-modal influence should not be under-estimated, adults mainly hear what they expect to hear.
There is little doubt most books on human perception will need revision over the coming years, so we're actually merely suggesting a research agenda based on evidence from other fields of science.
To get facts instead of rumours, please read the paper, https://tonmeistertagung.com/download/tmt30-2018-proceedings.pdf pg 111ff.
PS. For the record, I have never postulated humans can hear ultrasonic (>20 kHz) sound. On the contrary, actually. However, in pro monitoring, there can be acoustic consequences of ultrasonic sonic sound being reproduced vs (steep) 22 kHz filtering.
The wife thing is a common joke. While rummaging through some historical material I think I found the first instance of it. Or at least an early instance. The old Vacuum Tube Valley magazine [Issue 14, 2000]. An interview with David Hafler, certainly no tweako subjectivist. Dave was describing the development of the Ultralinear circuit with his partner Herb Keroes at Acrosound, before Dynaco:But in the real world of the audio enthusiasts, one constantly encounters the listener who implicitly claims to be so completely familiar with many 'qualities' one would expect to be subtle at best if not inaudible, that they can immediately say that change X has caused A to sound different from, and better or worse than, B.
And sometimes, in their parlance 'even my spouse could hear it'.
What is to be done?
https://www.audiosciencereview.com/...n-stoddard-on-blind-testing.11716/post-627043Jim Austin seems to be more of an objectivist to me. He prefers transparent sounding DACs and once famously double-blind tested dCS Bartok DAC (yes, DBT, in Stereophile with levels matched !) The manufacturer wasn't happy about it ))
His article summarizes two AES papers by Genelec researchers:
Time for Slow Listening
http://www.aes.org/e-lib/browse.cfm?elib=20547
On Human Perceptual Bandwidth and Slow Listening
http://www.aes.org/e-lib/browse.cfm?elib=19621
These papers basically claim that short ABX tests are inaccurate since humans can analyze maximum 40-50 bits of audio data per second.
An important academic initiative that will likely cause many a textbook on hearing/perception to be rewritten,
https://intelligentsoundengineering.wordpress.com/2021/01/14/aural-diversity/
I agree that "The assumption that we all possess a standard, undifferentiated pair of ears underpins most listening scenarios" is wrong and it can be proven by different results of different individuals when they perform the same ABX listening test. It can be seen in many studies that different people from the test group had different results and also here in the ABX tests posted. Ear + brain evaluation is not the simple engineering circuit, even if many oriented to engineering only would wish so.
An important academic initiative that will likely cause many a textbook on hearing/perception to be rewritten...
