Cabasse wireless
BrokenEnglishGuy
Well, cabasse also launch a wireless thing
1899 USD
CABASSE THE PEARL AKOYA WIRELESS ACTIVE​
TECHNICAL SPECIFICATIONS​
Maximum Sound Level​
115 dB mono
121 dB in stereo
Bandwidth​
30 – 27 000 Hz
Drivers​
Medium-tweeter 13 cm/5″ coaxial BCI
Woofer 17 cm/7″ HELD
Tweeter​
300 W RMS / 600 W peak
Medium​
Bass​
450 W RMS / 900 W peak
6 KG
retro
An LS60-killer..;)..?
Always liked Cabasse, they go their own way, always has. Like older Citroens..
As I am a coaxial-fanboy, I cant even imagine how good a triaxial can be? If done right, of-course..
Frgirard
30 hertz with 220mm*220mm*220mm?
115dB?
It's a magical speaker.
retro
Yes, DSP-correction of speakers could indeed be called magic. You should try it.
And 115db is not at 30 hertz. But you knew that already, didn't you..;)
People get so wound up about the new KEF LS60, as do I, but these seem even more exciting. Look much nicer, IMHO. And $3800 for the pair...
AdamG
Moderator
Reality
115dB?
Magical math more likely. Or measured from 2 inches. Without more details it does seem to be a stretch.
Jukebox
The Pearl Akoya and the bigger brother The Pearl are around for a while now but their presence is almost unnoticed unfortunately.
Listen to them both in mono and stereo and side by side LS50W2.
Although Kef measures better and is aming for a more neutral presentation, in a double-blind test I am not sure which one would I picked.
The Cabasse sounds amazing, has a different presentation than the Kef and I definitely prefere them on some tracks.
Just for fun I took home Cabasse Minorca 40 to test against my current Concept 300 speakers and I was intrigued how good they sounded especially in the midrange!
Sounded so good actually that I now have the Cabasse Murano's on my short list for the next upgrade together with Kef Ref1 and LS60.
Hope to get to hear them all next week in Munich's High End.
