Budget Preamp?
silver12
Hello, Im searching for some good PREAMP. Must have remote control, XLR is desirable...could be all analog...? (So no DAC...just preamp, neede for external DAC to power AMP.
JSmith
Algol Perseus
JSmith
TonyJZX
you're paying a lot of money for a HP amp that you may not need
Fosi is actually making a balanced preamp but I think progress has stalled due to their release of the ZA3 matching power amp.
BUt yeah... $600 for the kara seems to be it so far. Wish there was better hunting but no one seems to care bout this slice of the market.
S
silver12
JSmith
O thanks :)
S
silver12
Yes i know...my rabbit hole...searching second hand... :)
Deckard71
Does your DAC have volume control? It it has, and you dont have more devices, you dont need a preamp
TonyJZX
AaronJ
If you don’t need/want the headphone amp then consider a used Schiit Freya S. Probably $400-450 used.
Overseas
What about a good integrated with preout? Say Yamaha, Rotel etc
OldTimer
Why no tube pre-amp? Tube in the pre-amp and solid state in the amp.
TonyJZX
FrantzM
Hi
Extremely Transarent and inexpnsive JDS Lab Atom 2 Headphones amplifierr. It has Pre output , excellent performance, reliability . it is downright cheap. Around $125.oo.
One of the best headphones amp as well as one of the most powerful (over 2.6 Watts @ 32 ohms. See ASR Review Here
no XLR however.
Peace.
S
silver12
Hi
no XLR however.
Peace.
Thanks, but remote control :)
TonyJZX
good example
its like those "winner's dont use drugs" comparisons
this is your brain on dope
this is your brain on wheat bread, lean meat, greens and whole milk
