Budget Preamp?
OldTimer
good example
its like those "winner's dont use drugs" comparisons
this is your brain on dope
this is your brain on wheat bread, lean meat, greens and whole milk
Probably need warming up before doing the test.
Power Pop 23
Hello, Im searching for some good PREAMP. Must have remote control, XLR is desirable...could be all analog...? (So no DAC...just preamp, neede for external DAC to power AMP.
per post #3......
I have no idea when Fosi Audio will release this preamp. It may be significantly cheaper than a Schiit Kara. I say that only because the 'companion' ZA3 amplifier due for release this month is available for 125 euros at Audiophonics
EDIT - I do not see a provision for a remote control in the proposed preamp from Fosi Audio
Joe Smith
IF you can live without balanced, Schiit Saga S for $300...otherwise, yeah, their new one...quite a price difference.
JeremyFife
Scotland
What do you want a pre-amp for? How many inputs? Knowing what problem you are trying to solve might help?
WiiM Pro Plus? Analogue and Digital input, decent ADC so sends good digital out to your DAC. Adds PEQ and has a remote ... don't know if that helps?
S
silver12
In the end choose Topping A70, 423EUR in EU...didnt found better price...thanks to all :)
S
silver12
And in the (second end :)) end bought Vincent SA 32...will se, hybrid...
S
silver12
Just finished setup:
Streamer: Wiimpro
Preamp: Vincent SA 32
DAC: Schiit Modius
AMP: NAD C268
Speakers: Polk R200 (for now...)
Cables XLR 2x, qed.., Supra power strip 6x, filter
Very happy...its good choice for me...i used to listen Deezer before, more energetic sound, lots of high...but now is better Tidal, do little less bass (Vincent do better bass) and more airnes...sound is natural, organic...dont want too much detail-analytic sound...
