Buckeye Amps 2ch Integrated Amplifier
Buckeye Amps
2ch Integrated Amplifier Specifications/Features List (w/o Add-on card):
XLR Inputs (x2)
RCA Inputs (x2)
RCA Outputs (x2)
- User specifies desired behavior at checkout
- EX: User could specify Mono Sub outputs w/Low Pass Filter (24dB Octave, Analog)
- EX: User could specify Stereo Sub outputs w/Low Pass Filter (24dB Octave, Analog)
- EX: User can opt for no Filter Card and use RCA Outputs as full range Pre-outs
- Filter Card is user changeable (can order multiple iterations for minimal cost)
- If Filter Card is installed, user can switch RCA Output behavior (Pre-out vs. Sub out) via Remote
5-way Binding Post Speaker Outputs
- If user has selected a Filter Card for their sub outs, then a High Pass Filter (24dB Octave, Analog) will also be applied to speaker outputs
Volume Control Knob
- Stepped Attenuator (0.5dB steps w/128dB range)
- Press knob to mute system
Front Power Button
- Single press turns unit on
- Press to cycle inputs (once on)
- Hold to turn off
Remote control (metal)
- Includes Dim button for Front LED Display
Supported 2ch Configurations:
- NC252MP
- NC502MP
- Purifi 1ET400A
- Purifi 1ET7040SA
- Hypex NCx500
Software Features:
- FW Updates (via Phone or WiFi)
Add-On Card Features being explored (for future release)
- DAC
- Dirac Live
- Parametric DSP Filters
- HDMI EARC
Here are the PRELIM MSRP price targets for each 2ch Integrated models.
These prices do not include the price of the future upgrade board (to add additional features like HDMI input and possibly Dirac EQ). However, I will not be charging a profit on the upgrade board when it does come out, so it will be sold at cost and will be made so the user can install themselves (or send back to me for install for a small fee).
Please keep in mind these prices can change (up or down) as we get closer to actual production (hoping for Q1 2024):
2ch Hypex NC252MP = MSRP ~ $1095
2ch Hypex NC502MP = MSRP ~ $1195
2ch Hypex NCx500 = MSRP ~ $1450
2ch Purifi 1ET400A = MSRP ~ $1450
2ch Purifi 1ET7040SA = MSRP ~ $1750
tifune
Platin amp competitor? Someone has to pull WiSA out of the gutter, might as well be you!
ryanosaur
Cali
With expansion slots... you can pull and Emo and never use them! :p It's gotta be a Pre-pro with 20+ channels.
:D
Or not. *shrugs
Buckeye Amps
Buckeye Amps
Those will definitely NOT be the final vent hole sizes
Matias
São Paulo, Brazil
The integrated amplifier with sub out hinted here.
And with expansion board for DAC, possibly streamer?
Matias
São Paulo, Brazil
Here is a wish before the end product is even announced: please don't use a potentiometer, even a good one like Alps, even less if it is unbalanced. Ideally XLRs in, balanced buffer, resistor network attenuation, balanced pre-out to the power amp modules. Fingers crossed here.
Power Pop 23
I am looking forward to the official release. Consider sticking to added features that are not likely to require firmware updates, so as to not 'dilute' the customer service experience from Buckeye Amps.
Snoopy
Expansion slots are always welcome. Reduce electronic waste and no need to upgrade a otherwise perfectly fine working unit that is just outdated on the inputs.. but hopefully not like NAD did.. where generation 2 of the cards is out and not compatible with the hardware that would actually need them.
And shouldn't be some streamer card that is more expensive than a standalone streamer that does more
Buckeye Amps
Buckeye Amps
charlielaub
......coming soon!
But still not ready to officially announce or discuss in full detail.
So have fun with this really low res picture of part of the back panel of the prototype case.
I would love to see a combination multi-channel amplifier (e.g. with Hypex NCORE) plus DSP with 2-channels in and 6- or 8-channels out via 8-pole SpeakOn connectors!
If that is not in the cards at the moment, maybe you would consider reaching out to Al Clark at Danville Signal (in Minnesota) about the DSP part. He does that stuff very well and has some OEM boards in his lineup. Such a combo could be a great product that could appeal to both manufacturers as well as DIYers...
