In a previous message I mentioned another new feature I'm working on... Well, I'm going to try to introduce this one slowly...
https://app.box.com/s/qbrh3czrvudclkqs9n8lm806k3hzmjx5
The new feature is the ability to create custom
dynamic expressions that can be used inside the chart titles. For example, say you want the spectrum chart to include the FFT size, sampling rate, and the channels recorded on the title. Easy! Enter this text into the title setting:
My Chart {recordSampleRate/1000}kHz, {fftSize/1024}k fft, {channelsIn}
Here's the result:
Notice that you can insert variables into the title using the '{ }' brackets. What's more, you can even insert calculations to be performed on those variables. There are also ways to format the numbers to display a certain number of digits, or in scientific notation. Some other variables you can use, as an example:
{tdn}, {thd}, {noise}, {level}, {levelRMS}, {imd}, {sfdr}, {enob} and many others.
For a complete (long) list of variables and all the possible mathematical, logical, and text expressions supported, please see
here.
Now the title will always reflect your selected sample rate, fft size, and channel selections! You can do this with all the tabs in MT, each chart can have its own title.
If this works as expected, I'll add the same feature in other places where it makes sense in Multitone. But let's start with the titles. I'm sure there's plenty of opportunities to break things here -- this represents a lot of changes and some very complex code
