I’m venturing into DIY speaker building soon and I was wondering if any of you has recommendations on how to screw a speaker into a baffle.
That looks like a good price for cap head wood screws.A majority are just screwed straight into pre-drilled MDF or Baltic Birch.
I like T-Nuts, but have heard many criticisms about issues using them (from the t-nut not locking in or from it stripping out the wood, to being off by just enough to make the holes not match up).
I think more importantly is looking at use case and overall design. Specialty Subwoofers are going to require something much more different than a 6" Woofer and a Tweet in a 2-way Standmount.
In the US, you most commonly see something like these #6 or #8 Pan Head Scres used:
Then there are always the Cap Head Screws "for the European look!" (And yes, I have actually seen that very phrase used in an advertisement. )
I used T-Nuts in my dual sub build a year ago (and there are pics in that thread showing them). As you say ryanosaur, I had more than one not lock in, and I had to make several adjustments due to the one of the holes being off by the smallest of amounts. They are not very forgiving at all if you are off even a little. In addition that, I had to grind some down a bit (which you can see in the pics) because they were making contact with the driver frame. I'm about to build two more subs, and I'd already decided that I will be using the cap head screws this time and just pre-drilling holes for the exact reasons you highlight.A majority are just screwed straight into pre-drilled MDF or Baltic Birch.
Some of the Devastaor builds I seen have lumber blocks on the opposite side of the driver rim (rear-mounted) and they will use Spax screws through the favored Plywood and into the lumber. Those are for 21" Pro Drivers like the NSW6021-6 which I think qualifies as a strong Motor. But in the Dev, the Driver is hidden and rear mounted from inside the back resonator chamber.I use these wood screws too but not for drivers that have strong motors. @carbidetooth introduced me to nut Inserts or nutserts for short. Have been using them successfully in MDF but he secures them using epoxy. He sent me a video with this technique. Will post when I locate it.
I use threaded inserts into MDF for securing mounting brackets. I put a little glue in there, to, just to make certain it is locked in as best as possible. As you said, anything like that is tricky if you don't have much play for an imprecise pilot hole. I just looked up some of the Nut Inserts and surprised at the variety. I'm certain they all have their best use-case. Would like to see what you recommend for MDF, please. It's a definite improvement over the trick of using a Spade or Forstner bit and epoxying a standard Nut into the hole!I used T-Nuts in my dual sub build a year ago (and there are pics in that thread showing them). As you say ryanosaur, I had more than one not lock in, and I had to make several adjustments due to the one of the holes being off by the smallest of amounts. They are not very forgiving at all if you are off even a little. In addition that, I had to grind some down a bit (which you can see in the pics) because they were making contact with the driver frame. I'm about to build two more subs, and I'd already decided that I will be using the cap head screws this time and just pre-drilling holes for the exact reasons you highlight.
Slick! Thank you.Let me get that for you Rick, it's on my YouTube channel.
Even though I cut the pockets with router in the vid, I've done many with a twist drill. Sources for threaded inserts in the video description. I'm nearing completion on another build using this technique and it's now my go-to method.
