ShadowBoxer
- Joined
- Apr 14, 2024
- Messages
- 257
- Likes
- 177
Windows: freac, tag-scanner
EAC can rip directly to FLAC.I found an old licence of media monkey, it got a ripper, but don't really know it's good?
but, just trow in an old copy of my old database, with amazing result and play bit perfect, so it don't pass by the windows mixer, but play what in the file, so far, not much modifying tag, and mm ask when he made change!
my ripping sequence, wasn't right, i had album artist instead of artist album, but with mm, it work fine, but no streaming in all the house!
and apple airplay won't recognize those modify file!
so far, exact audio copy, seem right, i don't want any software to loudness my music, sorry replay gain truncate the upper range and the below range of music to make more compression than needed!
So for the tag:
Genre/artist/album/title/track/date
or
Genre/date/artist/album/title/track
any software/app, that does that automatically?
40000 titles, here!
after ripping, any software, to clean it? i have 3 database/copy that i put together, and now same track twice or third, without the same title!
best of, best of remastered, 20th best of, etc...
always the same album but the title was change to milk customer, and revoke past purchase!
ReplayGain is a simple-linear volume adjustment. It does NOT hurt audio quality. In fact it doesn't touch the audio data at all! It adds a "tag" that's read by the player software to adjust the volume before playback starts. And of course you can disable it in your player software and it won't do anything if your player doesn't support it.sorry replay gain truncate the upper range and the below range of music to make more compression than needed!
Thanks for this info. That seems the best way to do it Would happen to know if Roon supports this feature?ReplayGain is a simple-linear volume adjustment. It does NOT hurt audio quality. In fact it doesn't touch the audio data at all! It adds a "tag" that's read by the player software to adjust the volume before playback starts. And of course you can disable it in your player software and it won't do anything if your player doesn't support it.
