I know there's lots of opinions on this - I want to keep things as simple as possible as I have finally bought a DAC and want to make the most of it.
My setup is:
Mac Mini - remote computer hardwired to my digital files/hard drive using iTunes> Macbook Pro (circa 2010) +DAC wired into my preamp using Airplay to access remote files in main listening room.
My question: Simply Using Apple software & gear - If I want to use Bitperfect do I need to install Bitperfect on both computers or just the remote macbook pro? Any additional advice is valued. I would note: I do have a CAT5 ethernet cable that I could use for this, but no idea how that helps or if it is of value in making the most of things. Thanks!
My setup is:
