gasolin75
- Thread Starter
- #41
I don't know https://www.av-connection.com/?PGr=10331
OK, I just checked, but there is no info on Yamaha A-S301 "MKII" in Japan.@dualazmak, if you dont mind, would you check if there is maybe some news about a Yamaha A-S301 MKII in Japan?
I doubt it, but they know first if something comes.
All photos and manuals are from A-S301, nowhere can it be seen that it is MkII, except in their title.
Right, that's what i thought. Thanks a bunch.OK, I just checked, but there is no info on Yamaha A-S301 "MKII" in Japan.
Nor should you expect any, unless driving your setup at full tilt over long periods.Absolutely no heat problems
You could, in theory, force max current by adding a second a pair of speakers and drive them all at the same time. Second pair of the same would halve your resistance, which would double the current. At 2 ohms or less heat is an issue fast.
Uk thats no europe it's gonna be 25% + 22 euro in handling fee more expensive£200 or so the OP asked?
I don't know this amp personally, but a pal has an earlier one and it's very well made and using a European two channel Class D module which has proved reliable in a now discontinued UK made active speaker -
May be worth a look and for single ended RCA plug users, better than the PA5?
UK is very much Europe, just not European Union right now. They'll come around in time ;-).Uk thats no europe it's gonna be 25% + 22 euro in handling fee more expensive
There are too may issues showing up with the latest Topping wonder machine.
Plus their 'resident' spokesman appears to have gone AWOL.
My question is do any of the ones sold equal the peach that the makers sent to Amir?
I nearly bought one but none of my DACs have XLR; (& does it really sound any better than a Breeze TPA3116D2?.....btw Mine cost £12, and the seller went BIN only with his eBay listings thereafter!).
FWIW I think OP is right to be cautious.
Apologies gasolin75, I've sort of crashed your thread
They have been linked before, thanks. And welcome to the forumThese are great little units
